Threads: 50
City: Shenandoah,
Hi all, I’ve seen notes on service info concerning the 70 that there’s a difference between serial# B22,000 or above or below. I’m just starting on my 70 and the only number I see stamped on the rear apron of the chassis is 556792, no B in front of it so what exactly do I have? Thanks.
Ron
Bendix 0626. RCA 8BX5. RCA T64
Philco 41-250. Philco49-500
GE 201. Philco 39-25
Philco 37-116. Philco 70
AK 35 Philco 46-350
Philco 60B. Majestic 50
Philco 52-944. AK 84
Threads: 268
If it has a dual gang volume control it's the early model.
Threads: 50
City: Shenandoah,
Thanks Terry, early version is what I got then!
Ron
AK 35 Philco 46-350
Threads: 50
City: Shenandoah,
So in testing the tubes and general cleanup of my 70, I have discovered a little history behind my radio. I’ve seen 4 or 5 station call letters printed in pencil on the dial scale. Turns out they were all Detroit area stations. Then I find this sticker on one-off my 24 tubes. It’s from some shop in Detroit also. There’s what I presume is the set owners name printed on the back arch support! I wonder about how it made its way to me from Detroit to the Kutztown swap meet 4-1/2 years ago?
On another topic. What are you guys using for grille cloth? Looks like Richmond Designs is gone and I only find generic cloth on eBay! Thanks.
AK 35 Philco 46-350
(This post was last modified: 02-24-2021, 03:57 PM by 462ron.)
Threads: 7
City: bloomfield, ct
Have you tried this URL for Richmond ?
https://www.richmonddesignsinc.com/
He also sells on Ebay.
Threads: 7
AH, I see that the Home Page for Richmond designs is not operative.
Threads: 268
Maybe:
https://richmonddesignsinc.com/grille_cl...nd_24_x_24
But there isn't a good replacement for the 70/90 grille cloth.
Threads: 50
City: Shenandoah,
Ah there it is. Thanks guys. I don’t know why I couldn’t find Richmond designs. When I googled it and clicked, it came up 404! I’m a ways off yet from needing the grille cloth but will contact Richmond! Now onto cleaning up my dirty and slightly rusted chassis and electronic resto!
Ron
AK 35 Philco 46-350
Threads: 268
Have a look here and see if anything strikes your fancy. SPEAKER-FABRIC-SUPPLY | eBay Stores
Don't have my glasses on so can't see what they look like
Threads: 50
City: Shenandoah,
Thanks Terry, looks to be a few possibilities there!
Ron
AK 35 Philco 46-350
Threads: 72
City: Linn Creek, MO
Richmond Designs "Whiskey Rayon" is the one you need.
M R Radios C M Tubes
Threads: 50
City: Shenandoah,
Thanks Steve, that pin points it for me!
EDIT: Just ordered it, thanks again!
Ron
AK 35 Philco 46-350
(This post was last modified: 02-25-2021, 12:15 PM by 462ron.)
Threads: 50
City: Shenandoah,
Hi All, putting the dial back on my 70 and when the tuning gang is completely meshed, I can set the dial to read 55 but when I fully open it, I’m about a half inch beyond the 150 or high end of the dial. Can’t find anything in the Philco Library or Nostalgia Air as far as setting the dial before doing an alignment. Anyone have that info or should I just set my dial to split the difference between the low and high end of the dial. In other words, set it about a 1/4” below the 55 and that will give me a 1/4” above the 150 on the high end! Thanks.
Ron
AK 35 Philco 46-350
Threads: 49
City: Allendale, MI
both of my 70's and my 71 are set the same way. Just barely below 55 but way beyond 1500.
Threads: 50
City: Shenandoah,
Ok thanks Rob!
Ron
AK 35 Philco 46-350
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM |
91H Code 126 Restore
I'm pretty sure that the dotted line I circled in an earlier post signifies that it is applicable to the 226 model which...RealRider — 08:05 AM |
Philco 49-1040
Hello bob,
that underside looks like it is all original !
Sincerely Richardradiorich — 02:07 AM |
Philco 49-1040
Oh yes, many bumblebees and loktal tubes.
The cutout is for the speaker. Here's a photo from a different set.
Bob Andersen — 12:59 AM |
Philco 49-1040
Bob;
Looks like another "Bumble Bee" special, like my Brand Z T.O radios. Is that section they took out of ...Arran — 12:19 AM |
Philco 49-1040
Hello Bob,
You are like the home for lost tv's like how people bring pets home !
Sincerely Richardradiorich — 12:00 AM |
Philco 49-1040
I thought I had an arrangement to restore this set for a customer but his wife said heck no. Instead, he gave it to me....Bob Andersen — 10:29 PM |
I kept working on reassembly this week. I wasn’t able to solder for a few days while it was too cold (single digit low t...jrblasde — 09:27 PM |
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
There are currently 4326 online users. [Complete List] » 2 Member(s) | 4324 Guest(s)
