model 20 radio tubes.
What is the purpose of the 71A tubes. One of mine burnt out but, the radio still works. The sound is staticy(sp?)
Could this be because of the burnt tube? I did ground one of the capasitors with my finger to the ground on the chassis and the sound came clear.
But, the volume would reach a certain point then not go any higher. Any ideas?
I look forward to the answers. I'm definately puzzled. Icon_confused:
I can't vouch for the static part but the Model 20 uses a pair of 71As in a push-pull configuration for the audio output. What that means is that each tube works individually on each half of the audio cycle. So yes, with one removed (or defective) the audio will not reach maximum power and is likely to sound a bit distorted.
-Bill
Eico 232 VTVM Schematic
There are currently 8917 online users. [Complete List]
» 1 Member(s) | 8916 Guest(s)
