Does Sylvain Vanier still rebuild phono cartridges?
His website seems to have vanished and his email no longer works. I have a cartridge in need of his help.
-Mike
Mike,
According to this thread, Syl is no longer rebuilding cartridges:
[Note from admin - topic no longer available. See here: http://philcoradio.com/phorum/forumdisplay.php?fid=21 ]
Carl
Northern Panhandle, WV
When Syl shut his website down several years ago, he kindly donated many of his "how-to" instructions to the Phorum - including instructions on how to rebuild your own cartridges. You will find these as stickies in the Philco Electronic Restoration section of the Phorum.
He has other interests now, and I seriously doubt he has time to rebuild any cartridges these days. If he were still doing this, he would advertise as such.
There are currently 9168 online users. [Complete List]
» 2 Member(s) | 9166 Guest(s)
