Please, drawings of console cases ...
#46
Inches or centimeters? Realize these cabinets were made in inches.
Please give me some time to get the measurements. The unit is in my weekend home.
I recently bought this radio this summer.
#47
Without prolem. When it is convenient for you. It also does not matter in what units you take measurements, you can in inches. I can easily count them in centimeters. Please take some photos from the top, sides and back of the console. I will be very grateful to you.
Old Tube Radio Online Museum / Музей ретро радіо
https://www.youtube.com/user/RadioSvit?d...lymer=true
Sincerely Peter
З повагою Петро
#48
Hi RadioSvit,
Wonderful work. Your skills in building the cabinets that you reproduced is outstanding!!
I find it much easier to fix a radio electronically than to build a cabinet. I also fix cars and find it easier to rebuild engines and transmissions than to repair a rusted or dented auto body. I wish I had auto body skills, as I have a 1964 Lincoln Continental 4 door convertible that needs a total body restoration. This will be my retirement project.
Thank you, MrFixr55 . I also dream of a convertible because I love old cars. By the way, I repaired all the cars I once had myself and never used car service. Now I have a wonderful fairly old Swedish car Volvo 745 Wagon, which also needs a small body repair and I hope that this summer I will be able to do its restoration. Old cars have their own personal charm, which I really like
Sincerely Peter
З повагою Петро
Philco 91 Tuning Condenser
There are currently 10515 online users. [Complete List]
» 1 Member(s) | 10514 Guest(s)
