Threads: 17
City: angeles city,philippines
ive got a 7f8 tube thats a bit different than the other used 7f8's i have, yet seems to work the best of all of them with regard to sensitivity. the odd thing is i think its got a broken filament. on pin 2 which is a heater pin,there appears to be what i'd liken it to as 'BASKET BALL HOOP". IT sticks straight up about 3/4 of the way up the glass envelop. the tube has a nickel plated or stainless base and im guessing its sylvania. all the 7f8's i have,have this though most are square not round hoops and the hoops are closed by what looks like a wound filament. the round one appears to have endured an arrested landing at 160 knots as the hoop is distorted and the filament is open. it works just fine but as i aligned the if with it im sure theres a reason why nos 7f8's dont work as well. (i know about scraping the pins) the hoop isnt shown in the tube data sheet and ive no idea what it does or what its for, can anyone explain what this does and how it being broken effects the operation?
Threads: 114
City: Sneedville, TN
Without seeing exactly what you are talking about it is hard to say exactly; but, from your description, and the fact that the tube works at all, it sounds like what you are describing if the "getter." The getter is installed in a tube to burn off and consume the very last of the oxygen which might remain inside the tube after the vacuum is drawn. It usually has a tiny amount of mercury and a filament on it, and when the tube is finished being made, a current is run through it which heats up the mercury (or other metal) to high incandescence, vaporizing the filament and allowing it to combine with any remaining oxygen atoms. This is what leaves the silver you see on the inside of the glass envelope. It is a normal part of the manufacturing process.
Threads: 114
Here is a video about the manufacturing process for vacuum tubes. They use a different type of getter in it, but it gives a very good idea of the process.
[Video: https://www.youtube.com/watch?v=5WCWejeRR_s]
Threads: 17
and ive learned yet another tube radio detail. i do thank you
Threads: 569
And to check the filament all you have to do is to take the Ohmmeter to the pins ##2&7.
Threads: 114
Mike, do you remember, when we were kids, they used to sell these chepie "test them yourself" tube testers that basically only checked the filament for continuity? They had a neon bulb and resistor, so the current they passed through any tube wouldn't blow the filament, and if the filament was good the bulb would light up. Beyond that basic test they were worthless, couldn't tell you if the tube was weak or not, so if it was on its last legs, and could never function properly, it still gave a good reading.
Threads: 569
Yeah.....but at least it would tell you if the tube should glow or not
To tell the truth even a good MC tester does not guarantee that the tube that tests good will work.
A couple of tubes I bought on eBay for my Mac amp tested good with no gas, but blew the fuse upon warm-up.
I take it the tubes, especially id DC-coupled like it is in unity-gain outputs, they also should be tested for Cathode leakage.
The sound was overwhelming.
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM |
91H Code 126 Restore
I'm pretty sure that the dotted line I circled in an earlier post signifies that it is applicable to the 226 model which...RealRider — 08:05 AM |
Philco 49-1040
Hello bob,
that underside looks like it is all original !
Sincerely Richardradiorich — 02:07 AM |
Philco 49-1040
Oh yes, many bumblebees and loktal tubes.
The cutout is for the speaker. Here's a photo from a different set.
Bob Andersen — 12:59 AM |
Philco 49-1040
Bob;
Looks like another "Bumble Bee" special, like my Brand Z T.O radios. Is that section they took out of ...Arran — 12:19 AM |
Philco 49-1040
Hello Bob,
You are like the home for lost tv's like how people bring pets home !
Sincerely Richardradiorich — 12:00 AM |
Philco 49-1040
I thought I had an arrangement to restore this set for a customer but his wife said heck no. Instead, he gave it to me....Bob Andersen — 10:29 PM |
I kept working on reassembly this week. I wasn’t able to solder for a few days while it was too cold (single digit low t...jrblasde — 09:27 PM |
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
There are currently 4401 online users. [Complete List] » 4 Member(s) | 4397 Guest(s)
