Threads: 5
City: Minneapolis
State, Province, Country: MN
Good afternoon, gentlemen
I have a small tear in a speaker. I see several ads for black rubber cement for cone repair, but the writeups always talk about replacing the whole cone. That doesn't seem necessary. Shouldn't I be able to repair a small tear? This tear is about 1/8 to 1/3 of an inch long on both sides of a right angle. Otherwise the cone is perfect.
Is that what you guys use, or have you learned there is something better? Or <Gasp! choke!> do you recommend replacing the whole cone? It's a 12" off my Philco 41-285.
Thanks in advance.
Tom
Threads: 569
Small tear is repaired with rubber cement.
I use it and most people do. It would seem inexpedient replacing a whole cone due to a small tear.
Apply it from both sides, more that one layer. Not too thick,
Threads: 416
City: Boston
Have also used the cement and a patch like coffee filter as well to secure.......
Threads: 10
City: Santa Barbara, CA
Rather than rubber cement, I prefer the method described in this link:
https://philcoradio.com/library/index.ph...ker-cones/
Good luck,
Allen
Threads: 54
General purpose contact cement works well, goes on thin, remains flexible.
Threads: 30
City: Wellborn Florida
Have had good luck with rubber cement for small repairs. larger repairs small pieces of coffee filter soaked in Elmers white glue or kids school glue.
Threads: 114
City: Sneedville, TN
I use black RTV and paper towel. The RTV turns into actual rubber when cured. I spread a thin amount on the cone around the whole damaged area, being careful to brace things from the other side so as not to increase the damage. I spread a thin amount on one side of the paper towel patch cut large enough to cover the entire damaged area with about 1/4 inch on each side beyond. I then put on the patch, RTV side to RTV side, and carefully press it into place, again, providing support from the opposite side of the cone. Let it dry over night and you have a good, strong repair. You could use a coffee filter instead of the paper towel, but, since I drink instant coffee, and don't use coffee filters, I use what I have.
Threads: 416
City: Boston
My dad liked Instant, though he aslo used a MIRRO aluminum pot on the gas stove with Maxwell House ground that would make your hair curl, evaporated milk and 1 sugar.....has nothing to do with speakers.
Threads: 44
City: Roseville, MN
Here's my take, and the way I do it. The cone is stiff so it can move the air around it. I make cone repair with a paper using acid neutral glue. I have repaired the cone surround with a flexible layer of contact cement that stays flexible so the cone can move freely. This produces a mellow tone as the bass notes are better quality.
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM |
91H Code 126 Restore
I'm pretty sure that the dotted line I circled in an earlier post signifies that it is applicable to the 226 model which...RealRider — 08:05 AM |
Philco 49-1040
Hello bob,
that underside looks like it is all original !
Sincerely Richardradiorich — 02:07 AM |
Philco 49-1040
Oh yes, many bumblebees and loktal tubes.
The cutout is for the speaker. Here's a photo from a different set.
Bob Andersen — 12:59 AM |
Philco 49-1040
Bob;
Looks like another "Bumble Bee" special, like my Brand Z T.O radios. Is that section they took out of ...Arran — 12:19 AM |
Philco 49-1040
Hello Bob,
You are like the home for lost tv's like how people bring pets home !
Sincerely Richardradiorich — 12:00 AM |
Philco 49-1040
I thought I had an arrangement to restore this set for a customer but his wife said heck no. Instead, he gave it to me....Bob Andersen — 10:29 PM |
I kept working on reassembly this week. I wasn’t able to solder for a few days while it was too cold (single digit low t...jrblasde — 09:27 PM |
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
There are currently 4614 online users. [Complete List] » 2 Member(s) | 4612 Guest(s)
