model 60 speaker orientation
should the speaker transformer in a model 60B [version 6] be mounted on the left, top or right? i see pictures of it oriented each of those ways. including one in this video from a mister radio. about "restoring" a model 60.
https://www.youtube.com/watch?v=DopjlGU6x4I
I'm really not sure it matters, as long as it doesn't sit next the wood of cabinet. While audio transformers don't run "hot" I like it pointing down at the chassis... assuming there is room. I'll have to check my two 60s when I get home.
Interesting question.
There are currently 9635 online users. [Complete List]
» 2 Member(s) | 9633 Guest(s)
