  • 1 Vote(s) - 4 Average
Identifying my Record Player
Hi Everyone,
I’m new the the forum, and I’m not sure if this is the place to post this, but I figured I would give it a shot anyways.
I’m looking for anyone that has any information regarding my record player, as I know nothing about it (year, value, origin, anything!).
If anyone knows information about this machine I would really appreciate to hear what you have to say!
Thanks everyone
Hi and welcome,
I couldn't find anything on it. The model numbers that are used on the US models vs the same units out of CA are different. I did look around a bit but to no use.
Probably made around the mid '60s. Value 0 to maybe $40 US in good working order and looking like new. Origin ... Canada.
Hello Blake,
You have a self explanatory machine. All info is on it but the issue is that so many went undocumented from Canada. Going by the quarter on the tone arm I will guess it is not working properly? I have bought a few of these types and restored them. I dont think I have ever received more than $125.00 for one. I usually buy them for around $20.00-$40.00 as Terry said. It is in fantastic condition so if you were to try and sell it you would price it at about $100.00 and take the first offer over $65.00. Ebay is where you will get the best price. If you are keeping it then You can do a few things to help it run smoothly.
Best,
Kirk
Thanks for the replies. I won’t be selling it because I still use it. And the quarter is on the head to slightly weigh it down as it tends to skip without it (but works perfectly with it). I was interested to see what year this record player was from, but as you have alluded too, I haven’t found any information on it online. Thanks again!
These portable players have become popular again. New ones are being sold now at big retailers.
Portable record players were never a thing with the older audiophile crowd, but it should have a tracking weight adjustment on the arm somewhere. If you can get it to track at 2 - 3 grams, that would be good.. Record players tend to work best with record of a similar vintage. Track width and depth and stereo made the groves change over time.
I’ve definitely noticed that my that it tracks better with my older vinyl than the newer stuff. I’ll have to look at the arm and see if I can adjust the weighting ! Thanks.
