Zenith 9S367
I have a Zenith 9S367 that my grandfather bought new. Still sounds really good. Question: do you guys think I should go ahead and recap? Nothing has ever been done to this radio as far as I know. I have done a number of other radios, but I didn’t know if I should just leave this one alone. Expert opinions welcome! Thanks.
Well. What can I say....if you are only holding it as a conversation piece that "still sounds pretty good" - don't touch it.
However if you intend to sit in front of it, turn it on and listen to it awhile - yes, do the recap.
This said, those are pretty intense inside. Not really intense, but pretty so.
And when you start on it you might find out there are some wiring that starts to crumble and needs to be replaced.
And if you want to keep the spirit, (I am sure if it still sounds nice the resistors are more or less usable) you might get into re-stuffing the old caps so it looks the same. Which will take some effort.
I guess it is your call after all.
Thanks for the response. Will probably just go ahead with the restuff and all. Recently fell in way over my head with a junker Philco 38-116, and it worked out ok, so...   Thanks again.
38-116 is a marvelous radio. I do not think it much below the 38-690.
So.....from your prospective, unless you get the latter, not many things will exceed it.
And....if you tackled that one successfully, most other things will be a walk in the park.
Link for some info   http://www.nostalgiaair.org/Resources/509/M0025509.htm
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
Where do I look? 7B7 Suppressor? Both these radios seem to connect the SG to AVC. Which I am not sure why, but then ...morzh — 06:27 PM
