audio Transformer for 42-344
I have got a audio transformer in a 42-344 bad. Can someone point me in a direction
to find one for this radio.
thanks
alton
How about this direction. http://www.philcoradio.com/tech/audio.htm
The speaker table error?
Philco 70 antenna lead
