16B Cathedral Cabinet Restoration
Threads: 72
City: Linn Creek, MO
This 16B cathedral cabinet was given to me a few years ago by Ron Ramirez. Thanks Ron! I have two 5 band 16 chassis and will be installing one of them in this cabinet
[Image: https://live.staticflickr.com/65535/5131...9dca_c.jpg] Philco 16B Cabinet Restoration by Steve Davis, on Flickr
Clearly, the cabinet has some veneer issues. There has been an extra hole drilled in the front panel possibly, for a tuning knob somehow connected directly to the tuning condenser.
[Image: https://live.staticflickr.com/65535/5131...0ba2_c.jpg] Philco 16B Cabinet Restoration by Steve Davis, on Flickr
The wrap-around has had a couple of extra holes drilled.
M R Radios C M Tubes
(This post was last modified: 07-17-2021, 05:15 PM by Steve Davis.)
Threads: 272
City: Wilsonville
State, Province, Country: OR
This will be fun to watch!!
Oh - I remember that cabinet.
You are correct, Steve; the extra hole above the normal hole for the tuning shaft was there because some previous owner decided to remove the two-speed tuning assembly and connect a 1/4" shaft direct to the tuning condenser. It wasn't pretty. All of that was repaired, the tuning assembly was restored to its original design, and works fine now.
Good luck - if anyone can fix it, you can!
Threads: 72
[Image: https://live.staticflickr.com/65535/5131...a5f8_c.jpg] Philco 16B Cabinet Restoration by Steve Davis, on Flickr
I completely disassembled the cabinet.
[Image: https://live.staticflickr.com/65535/5131...a67c_c.jpg] Philco 16B Cabinet Restoration by Steve Davis, on Flickr
The easy first. Re-gluing the delaminated bottom.
On to the front panel. It probably be easier the make a new front but, I want to use as much of the original cabinet as possible so, I'm going to try to repair and re-veneer this one.
[Image: https://live.staticflickr.com/65535/5131...9af7_c.jpg] Philco 16B Cabinet Restoration by Steve Davis, on Flickr
[Image: https://live.staticflickr.com/65535/5131...4afd_c.jpg] Philco 16B Cabinet Restoration by Steve Davis, on Flickr
I have re-glued the delamination, replaced some missing veneer and plugged the extra hole. The panel has been sanded smooth. Now, I will add another layer of veneer.
[Image: https://live.staticflickr.com/65535/5131...e8e8_c.jpg] Philco 16B Cabinet Restoration by Steve Davis, on Flickr
The veneer that I have selected for the front panel.
[Image: https://live.staticflickr.com/65535/5131...7744_c.jpg] Philco 16B Cabinet Restoration by Steve Davis, on Flickr
[Image: https://live.staticflickr.com/65535/5131...39a1_c.jpg] Philco 16B Cabinet Restoration by Steve Davis, on Flickr
[Image: https://live.staticflickr.com/65535/5131...3de4_c.jpg] Philco 16B Cabinet Restoration by Steve Davis, on Flickr
First the edges are trimmed, the two pieces are pulled tight together with small pieces of tape, this is called "stitching", then the joint is taped long ways.
[Image: https://live.staticflickr.com/65535/5131...0d7a_c.jpg] Philco 16B Cabinet Restoration by Steve Davis, on Flickr
The veneer is folded and creased and a very small bead of glue is added along the edge.
[Image: https://live.staticflickr.com/65535/5131...39fa_c.jpg] Philco 16B Cabinet Restoration by Steve Davis, on Flickr
The veneer is flattened out and a sharp wood chisel is used to "squeegee" the excess glue. Use quite a bit of pressure and there will be no glue residue left on the surface to spoil the finish later on.
[Image: https://live.staticflickr.com/65535/5131...9cf6_c.jpg] Philco 16B Cabinet Restoration by Steve Davis, on Flickr
After the glue dries and the tape has been removed we have a piece of "book matched" veneer large enough to cover the front panel.
[Image: https://live.staticflickr.com/65535/5131...2c87_c.jpg] Philco 16B Cabinet Restoration by Steve Davis, on Flickr
The veneer has been glued and clamped.
(This post was last modified: 09-06-2021, 03:57 PM by Steve Davis.)
Threads: 268
Lookin' good!
Now I know why I've never done one I haven't twenty jorgensen clamps.
(This post was last modified: 07-16-2021, 01:32 PM by Radioroslyn.)
Threads: 156
City: Westland, MI
Terry, I don't think any of the BigBox hardware stores have that many clamps! Looking great, as usual Steve! Why don't you move closer to Michigan? I've got plenty of cabinet work in the wings! Take care and BE HEALTHY! Gary
Threads: 72
Looks better than original!
Threads: 30
Holy...clamps!!
Amazing work!!
Threads: 5
City: RUBY
State, Province, Country: South Carolina
And the grain V goes perfectly with the center knobs and dial opening.
Threads: 72
Threads: 72
Threads: 72
[Image: https://live.staticflickr.com/65535/5133...aac8_c.jpg]
Veneer has been add to the front arch.
[Image: https://live.staticflickr.com/65535/5133...6f4d_c.jpg]
I used a moulding head on the wood shaper to trim the veneer and take a very shallow cut to clean up the edge of the core. Next I will trim the outer edge of the veneer.
Threads: 72
[Image: https://live.staticflickr.com/65535/5133...0ce2_c.jpg]
Trimmed outer edge of veneer and sanded edge of arch.
[Image: https://live.staticflickr.com/65535/5133...7731_c.jpg]
I have attached the front arch to the base and test fitting front panel.
Threads: 72
Moving on to the wraparound. The wraparound is in pretty rough shape with bad veneer, extra holes and much delamination of the plies. As with the front panel, I want to keep as much of the original cabinet as I can. I am going to try repair and re-veneer. The veneer was easily removed.
[Image: https://live.staticflickr.com/65535/5133...7987_c.jpg]
Delamination along the back edge of the wrap
[Image: https://live.staticflickr.com/65535/5133...8d4c_c.jpg]
[Image: https://live.staticflickr.com/65535/5133...3d2e_c.jpg]
The glue holding the rear arch support was still holding quite well. When the support was removed, it pulled quite a bit of the inner veneer loose.
I forgot to make mention of it the other day, but last week I corrected another error on my schematic (applies to both R...jrblasde — 09:27 PM |
Gloritone 27 Radio
I have a model 27 that someone painted the cabinet brown. I've been trying to sell it for awhile but the cabinet paint m...Jim Dutridge — 02:30 PM |
Restoring Philco 96
Joseph
Yeah. The situaction is complicated by me living with my family in NJ while mom is in FL.
Were it not for my ...morzh — 10:55 AM |
Restoring Philco 96
Best of wishes for your mother. I hope she recovers well. My mother struggles with sciatic pain as well, so I am familia...jrblasde — 10:41 AM |
Restoring Philco 96
Well, because I am away, I cannot check it. Hope mom becomes better enough for me to get back.
I think I will be here f...morzh — 10:27 AM |
Restoring Philco 96
Nice find! I hope it completes your console.jrblasde — 08:45 AM |
Gloritone 27 Radio
Hello john,
That, is the first time I have have seen or heard of that brand and model.
Welcome to the party !!
Sincer...radiorich — 08:08 AM |
Thank you! I’ll probably use the half-round molding and tone it to match the original. Thanks for the replies!Max T — 06:34 AM |
Gloritone 27 Radio
I'm kind of late to this thread, but Buzz1151 has a 3 part restore series on the model 27:
A little bit of extra t...Eliot Ness — 05:48 AM |
You can get half-round moulding in various diameters at any home improvement store. That way the flat edge is uniform. ...GarySP — 12:03 AM |
There are currently 1588 online users. [Complete List] » 1 Member(s) | 1587 Guest(s)
