Good way to fix this blemish?
Would like some advice on repairing this small blemish. It is a light gouge but it does not go all the way through the mahogany veneer. What products would work best? Here are pictures:
That's almost a job for "tinted lacquer" sprayed from an airbrush in very thin layers, blending edges by lightly overlapping as you fill to the centre.
If it really is small, try one of the (hot) wax sticks in the appropriate color.
Pictures just loaded - not small. Yes, some toner carefully applied with a brush or blotter. You can make it good enough that other people won't see it - but you know where to look. classic toner, dark walnut. A repair that is too dark will look better than a repair that is too light (to me).
Thanks for advice y’all. Now, It’ll just be a matter of skill ?
It'll be a case of patience, more than skill I think. The important thing to remember is that this finish is NOT a stain IN the wood grain. It is a colored (tinted or toned) surface layer of a hard finish (lacquer) OVER the wood grain.
And yes, I agree that slightly darker will likely work better than a lighter tone.
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
Where do I look? 7B7 Suppressor? Both these radios seem to connect the SG to AVC. Which I am not sure why, but then ...morzh — 06:27 PM
