Question on Model 87
Specifically, the subject radio here:
https://ronsradios.com/2021/07/14/philco...rs-part-1/
I have decided to use the bypass tricks discussed here to take care of the two audio interstage transformers, both of which have open primaries.
My question concerns the large three-section resistor, part (35).
Refer to the schematic here.
The resistor's sections are 3785, 157, and 640 ohms.
The 3785 ohm section is open.
A friend suggested that I scrape off the resistance wire of that section (only) and add a resistor across those terminals. However, the resistor is coated in ceramic, making that impossible.
Any suggestions? Since this is a cylindrical power resistor mounted by a screw and nut, it looks like this may be difficult to replace.
Thanks.
You don't want to just put a resistor across the open section as you mentioned in your blog. So if you did not use one of those terminal lugs but instead fashioned a separate lug epoxied to the ceramic so that it has no chance for a potential reconnection of the open resistor you could put a new resistor across to the new lug. Just a thought...
Hmmm. I'll look into it. Thanks.
There is a tip that I've heard of but haven't tried. The theory is that the nichrome wire oxidizes at point of contact on the solder lug. Chip away a small amount of the enamel to gain access the oxidized area. Clean up the connection. Not sure how you reconnect nichome wire short of crimping or spot welding. Use a bit of JB weld to replace the missing enamel and color to match.
About the same time the 87 came out the National Company out of Mass produce a receiver called a SW-3 which a similar problem. Have serviced several of them have used Ohmite Divide ohm resistors. They have a side that the nichrome is exposed and slider that can be adjusted from from one end to the other. If more taps are needed add more sliders.
I have always thought it to be a combination of corrosion and mechanical movement. The nichrome can get super hot. Expansion rate is 14.0E6 + or - %10 (so says google) but the contact point with the tinned copper terminal, while being a heat sink, is probably going to have some ware/ expansion in that contact area. A crimp with some plyers SOMETIMES fixes it.
I appreciate the responses. Thanks.
Here is the resistor in question.
I tried the crimp with pliers - no joy.
I then decided to do something else.
I'll be posting this on my blog in the near future, but you can see it right now.
Using my Ryobi "Dremel" tool - the best $5 I have ever spent, and yes, I bought it new on closeout, about 25 years ago - I ground through the outer coating and removed part of the resistance wire as shown. This way, I will be able to connect a new resistor (or resistors) to the original terminals, without worry of the original resistance suddenly becoming "active" again.
(H/T to Ed Locker for the idea.)
I will likely coat the ground-off area with J-B Weld before reinstallation. And, in case you were wondering, I did the grinding on the bottom side, where it will not be seen once reinstalled in the radio.
Ok. If you have followed this post thus far, I now have another question for you.
Given that Mouser Electronics has suitable power resistors in 3600 ohm and 180 ohm (which would add up to 3780 ohms, very close to the original 3785 ohms) and in 3900 ohms  -
Would you replace the 3785 ohm section with a 3900 ohm resistor or with two resistors, 3600 ohms and 180 ohms?
I think I already know the answer, but I would like to know your thoughts/opinions.
Thanks in advance for your comments.
I wonder if you could actually put 10W resistors inside of that sucker. The mounting bolt would have to move/change. Then drill holes out to the terminals.
My thoughts previously, were more inline with candohm construction. I would think that these would be subject to less corrosion.
Ron, I think I would go with the 3900 ohm, it would be within 5 percent of the original.
M R Radios   C M Tubes
Thanks Steve. I'm going with 3900 ohms. Resistors (this 3.9K plus a 68K, 1 watt to replace the 70K resistor) have been ordered from Mouser.
Russ, the only problem with putting resistors inside the ceramic tube is that then you lose the ability to attach it to its mounting brackets. It depends upon a very long screw, with bolt, to hold it in place.
Well, crap. All this work only to find out the power transformer is bad - partial short in one half of the HV winding.
I've posted a "Wanted" ad on this subject.
Since I just went through a Model 65, just curious about what you intend to do about the cap and resistor combos like the 3292a in the photo. I would imagine that those could be restuffed?
I saved the ones from the 65 that I had to replace just in case...
Richard
Those are super simple to restuff. I have a book that lists every internal layout of those block caps. All you have to do is cut the wires where they loop around the solder lugs, then heat the block up a bit to loosen the grip between the tar and the sides of the block, take a small screwdriver or a brad or paper clip or some such and just push the insides out. Install your replacement cap(s) and/or resistor and there you have it. I repot mine with paraffin wax, but you don't even have to do that.
RGallahue
Brenda has already answered your question, but I also addressed that issue here:
https://ronsradios.com/2021/07/19/philco...rs-part-2/
As Brenda said, they are super simple to restuff.
91H Code 126 Restore
Hi Nick, Usually the dashed lines connected to components means the part is a substitute in the circuit for specific ...RodB — 09:42 AM
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
There are currently 4515 online users. [Complete List]
» 2 Member(s) | 4513 Guest(s)
