37-84 Cathedral Question
I just picked up a 37-84 code 121. Most of the pictures I see of the 37-84 are with vertical grill bars and photo finish. Mine has no bars. The grill cloth is almost fully exposed. And there is no photo finish. Were there different cabinets for this model? It is original as the labels are in place.
You could take a look in the Gallery or post a pic of it and someone can tell you what's what.
I did find it in the gallery. It's a undocumented version.
http://www.philcoradio.com/gallery/1937b.htm#q
Thanks.
Nice find! If it needs help pop down to the Electronic Restoration page.
Philco 91 Tuning Condenser
There are currently 8758 online users. [Complete List]
» 2 Member(s) | 8756 Guest(s)
