my latest project built reproduction filter capacitor
Hello Ron,
Yes that one of the reasons I choose those capacitors .
Sincerely Rich
It's definitely simpler using a Solen cap, since they are a larger value in one package, but those are only good for the single section cans.
Hello Arran,
I agree with you ! Anyway Christmas break was great now it is time to get working on this radio again.
Sincerely Rich
Hello guys,
Well over the winter I will be doing something similar but stuffing cans on in my Philco 38-10T
Which has two Filter can's one containing a 12ufd and the other which contains two capacitors a 4ufd and a 8ufd in the same can .
P.S. I will post photos of that Zenith chassis because my next item for that chassis is to make repo dog bone resistors .
Hi Rich, Since you are working on a 38-10, and since this thread has a lot of discussion of re-stuffing electrolytic condensers, and such. I figured you might like to go over my own thread about restoring a 38-10. The two section electrolytics are a pain in the butt to rebuild. Unlike the single section one which are filled with a liquid, and are pretty easy to rebuild, the two section ones are "DRY ELECTROLYTICS" and are completely filled with goo which is a bear to get out. I found it easier to just make reproduction cans. Here is a link to my thread... https://philcoradio.com/phorum/showthread.php?tid=22318
Hello Mike,
that Sounds Great my Chassis is missing one can thou and I have not pulled the chassis to see which one is missing .
Philco 91 Restore Code ??
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 6156 online users. [Complete List]
» 1 Member(s) | 6155 Guest(s)
