Philco 89 bypass capacitor voltage
I'm working on a Philco 89 (code 123) and I'm ready to replace the 5 bypass capacitors in the metal can under the chassis (part no. 4). They are .05,.05,.09,.09 and .25 uF.
I have some capacitors of those approx values rated at 200V. Can I get away with that voltage? or do I need to get capacitors with a higher voltage?
Mark Icon_problem
Yes and no Icon_smile For #4 and #39 200v would suffice but for the other three you really should use 400v or higher.
Thanks for the help.
One more question, if I may, at the risk of showing my electronic ignorance....
There is a bakelite cap block no. 17 which has two 0.09 caps in it. One is labeled 17 on the circuit diagram while the other is labeled 29. It is unclear to me if I can use my 0.1uF, 200V capacitors to rebuild that block??
Mark
Yes, on both caps. There's minimal voltage on both of those. Without doing math its probably about 20 volts or so. And 0.1 is fine to replace 0.09. Philco did some funny things like noting "99k" resistors instead of 100k because of poor factory lighting. I suspect that their choice of "0.09" was intended to mitigate reading errors between 0.1 and 0.01
Thank you exray. I can continue with my rebuilding now.
Mark
Hi again, Mark.
Next time buy all 630v caps and this will never again be a question! A few cents more but at the price for shipping when you only need onesie-twosies you'll be better off in the long run.
exray Wrote:Hi again, Mark.
That's good advice and what I usually do. I happened to run out of my 630V caps and was scrounging through my supplies when I found a bunch of 200V and 250V caps.
That's what prompted the questions along with my limited knowledge of electronics.
The speaker table error?
Philco 70 antenna lead
