philco 37-620 wiring
I am in the process of restoring a Philco 37-620 tombstone ( trapezoid) radio,,, i have searched over every wiring diagram i can find for this radio and cant find this wire on any of them ... the wire appeared to have been cut   but hangs loose at the front of the radio close to the  on-off switch  and the 2 caps.  what appears to be a white wire with a green stripe.. runs across the front of the radio to the opposite side and  solders into the strip  on the third solder connection.  any suggestions or knowledge would be greatly appreciated
Royce,
What you need to do is start with what you know. You have a wire that has one end hanging unconnected. The part that you know (or can quickly find out) is, where does the other end of this wire connect? It might be a tube socket pin, or resistor, or something else. Once you have that, look at the schematic (not the wiring diagram) and find that tube pin or resistor. This information alone might be enough to tell you where the open end of the wire should connect. If it doesn't, then start from the tube pin/resistor etc. and keep working backward to find whatever else it/they connect to. Mark up your schematic as you go (make an extra copy just for this), but eventually, you should be able to figure out the connection point for the open end of that wire.
I hope this helps.
Jon
Hi Royce and welcome,
If you could post a picture or two of it we can probably get it sorted. I have a 37-620 chassis on the bench as we speak.
What should I offer?
I have an opportunity to acquire this radio-phono, but the owner wants me to make an offer.  Tried searching images, but...nocusr — 12:35 PM
I have an opportunity to acquire this radio-phono, but the owner wants me to make an offer.  Tried searching images, but...nocusr — 12:32 PM
I have an opportunity to acquire this radio-phono, but the owner wants me to make an offer. Tried searching images, but...nocusr — 12:29 PM
So, I unwound the coil; it is 700 turns of AWG40 wire. I modeled it on a couple of different calculators and I got about...morzh — 12:29 PM
Ron From the conversation, it was my impression he was a pretty old dude who is looking to place his radios in good h...morzh — 12:16 PM
Philco 49-1040
Yes, and it's surprisingly common for early TVs to be mostly or all original. My thinking is that they were retired ear...Bob Andersen — 11:59 AM
91H Code 126 Restore
Hi Nick, Usually the dashed lines connected to components means the part is a substitute in the circuit for specific ...RodB — 09:42 AM
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM
Philco 49-1040
There are currently 3942 online users. [Complete List]
» 1 Member(s) | 3941 Guest(s)
