Philco Model 86
Hello and thanks to all of yall that helped me with my 42-123. I am now going to start on the 86 that I have had for years but not the knowledge to tackle it. I have watched Buzz1151's videos several times and find them informative. One thing still confuses me is what caps to use for the filter condenser block and the filament by-pass can. From what I have read on the phorum, not electrolytics, but film. I would appreciate advice from you experts on part numbers on what yall feel is best before I order anything. I did order a P-T156 audio interstage transformer which I believe will work for the push-pull input transformer, hopefully.
I will appreciate any and all help and guidance.
George
Film caps. Electrolytic caps will overheat and short do to the ripple current at the input cap.
The filaments are power by an AC voltage. AC volt is fine on film caps but Not on electrolytic caps. They are polarized and have + and - . AC is constantly switching back and forth polarity wise 60 times a second. E caps don't like it one little bit and they short. Gotta go with film caps.
Have use them for single plate to single grid and single plate to push pull grids. Works fine in both applications. The only thing is that you have to be mindful of not to exceed the primary's 10ma current rating.
https://www.tubesandmore.com/products/ca...c2341a2445
https://philcoradio.com/library/images/schem/86.jpg
Thanks Radioroslyn for your response. Question, they dont come in 4uF or 2uF, would the 4.7 and 2.2 be ok?
Hello George,
Welcome aboard and as Terry Said Film Capacitors are what you want to use !
Good Luck and I will keep a eye out for your posts.
2.2 and 4.7@630v are ok.
The original 4mfd value is somewhat critical in that if you increase the value a lot it will raise the output voltage of the power supply. At .7 mfd should amount to much. If you put 10 or 20 mfd instead of 250v output you'd be at like 375v and your set would hating you.
Thanks Terry andd Richard.
I'll get them on order. I will try to post a few pics of this as it is now, not near the shape that Buzz'z is, but I   will give it a try.
A little tip. If the dial cord is entacked lub the bushings on the tuning cap so there is the least amount of stress on the cord. It's a pain to restring. Looks like you got a little rodent damage... Good thing It's got a steel cover over the bottom of the chassis.
Hello George,
I see where your transformer became lunch for a little mouse !
I have a Zenith 1930s radio I even found a nest under the chassis .
That doesn't mean anything. I have a Philco 65 which had mouse damage under the chassis - inside that steel cover. If a mouse wants to get into something, and if there is any way it will fit through the smallest hole, it will do so.
https://ronsradios.com/2021/08/02/philco...rs-part-1/
LOL ! yeah... mice... remember the RCA C9-4  ?...
[Image: https://64.media.tumblr.com/27b79e2863d8...9b6ac6.jpg]
It's something we all end up dealing with eventually.
Mice................aaaargghhh, time to set the traps.
Hello Mike ,
my Zenith is a model 715 Tombstone anyway nest was not as bad as that but do have rust to deal with .
Just glad My Zenith model 908 chassis did not have a nests or real damage .
I was looking at the Zenith 715 it costed $49.95 in 1933 and using the inflation calculator that is a whopping $1062.74 in 2021 !!
https://philcoradio.com/phorum/showthrea...=philco+86
My 86 (same radio) thread. You could see what I used.
Morzh,
That was a nice job you did on your 86 !
Thanks Rich.
What should I offer?
I am not sure what radio it is, but seems like a 1950 AM/FM set. Or from 1948, possibly one similar to 48-1264. In any ...morzh — 12:44 PM
I have an opportunity to acquire this radio-phono, but the owner wants me to make an offer. Tried searching images, but...nocusr — 12:29 PM
So, I unwound the coil; it is 700 turns of AWG40 wire. I modeled it on a couple of different calculators and I got about...morzh — 12:29 PM
Ron From the conversation, it was my impression he was a pretty old dude who is looking to place his radios in good h...morzh — 12:16 PM
Philco 49-1040
Yes, and it's surprisingly common for early TVs to be mostly or all original. My thinking is that they were retired ear...Bob Andersen — 11:59 AM
91H Code 126 Restore
Hi Nick, Usually the dashed lines connected to components means the part is a substitute in the circuit for specific ...RodB — 09:42 AM
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM
Philco 49-1040
Philco 49-1040
There are currently 2944 online users. [Complete List]
» 2 Member(s) | 2942 Guest(s)
