Threads: 13
City: Greenwood
State, Province, Country: Delaware
I've been following Bob Andersons trials and tribulations on his 90, but this one in pretty good shape overall. Like his, this has a single 47 output tube.
What's missing:
-the Large tube shield (with tube layout sticker)
-another shield on the other side (there's a clip there)
-one of the original filter capacitors
-no stickers!
Other:
-strange shape of the volume control shaft, makes the knob wobble. Don't want no wobbling knobs!
-strange red grounding wire on the choke housing to the chassis
-deformed tuning dial
Tubes all test good (2 may be original). I use an old Signal Corps I-177 tester.
The tubes all light up with the rectifier removed.
Transformers, including PT, speaker, output transformer, and choke all seem to be good except for the RF 1st Det. coil (7), open primary. What a surprise.
BTW, I've found that a dab of WD-40 on the grid caps and tube pin sockets make them suckers jump right out of there! I use a q-tip. Also grip tubes by the base, not the envelope.
And, now for your viewing pleasure:
Notice the shape of the volume control shaft
Big red ugly wire grounding the case which is insulated from the chassis (?!)
All that green stuff is fragmented wire.
91 turns required (don't laugh at my winder! it works) That's 3m electrical tape sticky side out, one layer.
That's all folks (until round 2)
Threads: 43
City: Chicago, IL
Regarding the filter choke. It looks like there are phenolic insulating washers on the mounting screws. Mine is metal on metal. I'm thinking they might have been trying to reduce hum by making a single, solid grounding point ?
Also I suspect that is a replacement volume control. You could try building it up with some solder or JB Weld.
(This post was last modified: 11-17-2021, 10:26 PM by Bob Andersen.)
Threads: 13
City: Greenwood
Thanks Bob- i will try to solder a shim on the shaft- and remove the ugly red thing and put choke back like its supposed to be.
I'm thinking of putting the tubes back in before I replace caps and resistors to see if it's alive. I would bring it up slowly and monitor AC voltage and current, as well as B+. There's a spider web of replacement capacitors and lifted resistors floating in mid-air.
Or is that not a good idea?
-Simon
Threads: 43
City: Chicago, IL
I suggest you did what I did with mine.
1. Disconnect or replace the AC line filter caps. They are in circuit even with the radio turned off and have a nasty habit of popping.
2. Put all the tubes in except the 80 rectifier and power it up. No need to do it slowly, just go for 117 VAC. All the tubes and dial lamp should light up. You can check the power transformer secondary by stick your AC voltmeter probes into the 80 tube socket. 5 volts across the fat pins. Something like 500-700 across the smaller pins.
3. Replace the two electrolytic caps and apply full power using a dim bulb or similar current limiting device.
I don't really see the point of slowly powering it up unless you're trying to reform the old electrolytics.
Threads: 13
City: Greenwood
Already did the no-rect-tube-PT-voltage-check, all ok. Didn't think about AC line filter caps, anyway they didn't 'pop'.
OK on the electrolytics, I will check them out next, then see if it's alive-
Thanks
Simon
Threads: 113
City: Omak
State, Province, Country: WA
Hello Simon,
Well I may have a Volume control in my stash of Controls but I will not be able to check that stash till winter break .
Threads: 13
City: Greenwood
Thank you Richard, that is good of you.
Threads: 13
City: Greenwood
It's looking like the 3,500 ohm segment of the large tubular power resistor is bad. It's measuring 70K building up to 90K with a digital VOM. I tried resoldering the ends, but that stuff they use is flimsy cloth covered stuff and just came apart.
Question is, what watt 3.5K resistor will work?
-Simon
Threads: 572
Simon
What section on the sch is the 3500 Ohms?
Threads: 13
City: Greenwood
Bottom right 58 between 3 and 4 Mike
Threads: 3
City: Drexel Hill
State, Province, Country: PA
Hi Simon...I'm new to the forum and vintage radio restoration in general. Having a problem with the same resistor...only 1750 ohms from end to end. 200 ohms from terminal 1 to 2...1750 from 1 to 3 and 1750 end to end. Resistor starts to burn up at terminal one on power up. Popped the electrolytic connected to it last night.
Threads: 13
City: Greenwood
Hi cnob, I was tempted to fire this thing up but now glad I didn't. I'm going to trace out all the circuits first because the wiring is a mess. BTW, the 2 filter capacitors 56 and 57 should be 6 uf
Threads: 3
City: Drexel Hill
Threads: 13
City: Greenwood
Update on the Tubular Resister 58 - now it's working!
I unsoldered the lead going to F.C. socket (terminal 4) to isolate that part of the resistor, and must have reflowed the solder, because it then measured about 3.6K. Soldered back the lead and measured 3.4K or so. I think condenser 24 is having some weird effect on it.
-Simon
Threads: 572
SImon
I am not sure, but I think it dissipates 5.7W. So you need 10W rated resistor to sub it.
Gloritone 27 Radio
The 20 pot has two sections: one is the Antenna attenuator, the other is the cathode bias one.morzh — 12:11 PM |
Gloritone 27 Radio
Does the Philco pot have only 1 element (2 or 3 terminals) or is it ganged (5 or 6 terminals)?
You state that one con...MrFixr55 — 11:52 AM |
Gloritone 27 Radio
Yep. It is a light version of Philco 20.
I guess it was soon after the 24 tube appeared on the market and everyone start...morzh — 11:04 AM |
Gloritone 27 Radio
Hello guys,
Well i just looked at my Gloritone and low and behold it is a model 27 !!
Yes, Mr Fixr55 I have couple Sea...radiorich — 10:54 AM |
Gloritone 27 Radio
It sure looks to me like someone was working off two schematics. I have been checking every part and wire with both sche...dconant — 10:51 AM |
Gloritone 27 Radio
Hi dconant.
I have not worked on the 27 but have worked on the somewhat similar Gloritone 26 for a friend. These are...MrFixr55 — 10:41 AM |
Gloritone 27 Radio
Hello dconant.
You can also use film capacitors !!
Maybe someone was working off of two schematics.
It sounds like yo...radiorich — 10:02 AM |
Philco circuit master 7004
If you are trying to sell this item, there are rules here about that.
It needs to go to "For sale or trade", ...morzh — 08:41 AM |
If anyone is interested in owning this item. Lemeno.
Shoot me an offer or something cool to trade if equal value. I ...Jdow927 — 01:28 AM |
Hello jdow927,
Welcome to the Philco Forum and what great gift that meter looks to be in nice shape .
Those jacks were...radiorich — 12:50 AM |
There are currently 3614 online users. [Complete List] » 3 Member(s) | 3611 Guest(s)
