Threads: 5
City: CLARKSTON
State, Province, Country: MI
Working on the tuner chassis of my pretty much original 38-690; I have replaced 40 paper/wax and electrolytic capacitors (restuffed), and 10 out of spec resistors. Repaired a lot of veneer and refinished the cabinet. In addition, I have rebuilt the condenser coupler, replaced the tuner bushing, and the sub chassis isolators. And the dial.....
Questions that I have are-
The band mask slot for the broadcast band does not line up; the beam lens center is on the edge of the window- is there a way to adjust it? The others are ok.....the arm on the band switch is pot metal, so cannot be bent, and the arc shaped link can’t be adjusted.
The band knob (repro) swings from horizontal to vertical; is that correct?
The pointers on the 4 other knobs do not seem to point in logical directions ( not from 7 o’clock to 5 o’clock)- normal? All 4 knobs are the same part from what I can tell; two of the shafts are flatted on opposite sides, but installed either way, the pointer doesn’t swing symmetrically.
It was disassembled when I found it.
(This post was last modified: 11-25-2021, 09:06 AM by RGK20m3.)
Threads: 271
City: Wilsonville
State, Province, Country: OR
Welcome to the Phorum!
sorry, I haven't worked on a 38-690 so others will have to help out.
Threads: 5
City: CLARKSTON
Probably answered my own questions; Google images show the band switch knob swinging to the left, as mine does. The Bass pointer lines up with “off”, and the Magnetic Tuning knob lines up- the other two are the ones that puzzle me.
Threads: 271
City: Wilsonville
Glad you found something. No one else chimed in yet so ....
There are a couple 38-690 restoration threads that might be helpful. Don't know if you've seen them.
https://philcoradio.com/phorum/showthrea...ght=38-690
And there are others is you search for 38-690 in the Phorum.
Hope that helps.
Threads: 5
City: CLARKSTON
Trust that I have read them all multiple times (sometimes after learning the same myself before reading). I powered up the dial illumination and the beam indicator on the broadcast band isn’t too bad, so I will leave it. Now, on to the power chassis, which will be comparatively easy.....
Threads: 5
City: CLARKSTON
Well...the power chassis is a mess. The interstage transformer has an open primary, one choke is open, and the AVC 6J5 is broken. Theory that I have is the filter cap shorted, which caused excessive current through the choke, which burned out. This is on the side with the candohm voltage divider resistors; if the choke goes open, no current flows, which means no bias voltage source. As the 6F6 driver is fixed bias and fed from the other power transformer, no bias caused excessive plate current, which burned out the interstage primary winding. Oh, well.....
Threads: 569
Yeah.....and their interstage is a complex one.
Heyboer rebuilt mine.
After 3 attempts
They are good folks. But got really mixed up.
The saga starts here.
I read somewhere that Heyboer is now out of business.
Their website is still up:
https://www.heyboertransformers.com/
I would contact them and confirm they are still rewinding transformers before proceeding.
Threads: 569
Threads: 113
City: Omak
State, Province, Country: WA
Hello Ron,
I see they have a up to date Facebook page with a Christmas photo !
Sincerely richard
Well, it could very well be that what I read was fake news. I hope Heyboer is still around, they do great work.
Threads: 5
City: CLARKSTON
Well, the cost to rewind the interstage transformer and a new filter choke isn’t in the cards for now, so I came up with a temporary (maybe permanent) solution-
As 4 of the 6 filter caps on the power supply were not original, I restuffed the 2 originals and replaced one of the others with a multi section cap, along with a discrete axial cap- this got the power supply handled and left 3 can cap holes, 2 of which I filled with dead caps (leads clipped) for visual purposes.
I then made an adapter to install another octal socket were the last cap was. I fully disconnected the interstage transformer and bundled the leads out of the way, in case I decide to have it rewound. I wired the additional octal for a 6SN7 split load phase inverter, with a DC coupled driver. I installed a single ended output transformer on the 6F6 to drive the tweeters.
Now I have a functional on all bands 38-690, with no permanent modifications.
Threads: 30
City: Wellborn Florida
Good work around. The radio works on all bands an in the future could always be returned to original build. David
Threads: 5
City: CLARKSTON
Getting ready to perform the RF alignment on my 38-690, and I have a question- the broadcast band works/ receives fairly well, but the dial is off by 40kc. Mechanically, the dial stops line up with the scale ends. Any tips, or will the standard process correct this?
Threads: 569
Well, either you turn the dial itself (forgot if this could be done; there is a notch on the inner ring) or this is what the alignment is for: you simply adjust your padders.
Users browsing this thread: 13 Guest(s)
What should I offer?
I am not sure what radio it is, but seems like a 1950 AM/FM set. Or from 1948, possibly one similar to 48-1264.
In any ...morzh — 12:44 PM |
I have an opportunity to acquire this radio-phono, but the owner wants me to make an offer. Tried searching images, but...nocusr — 12:29 PM |
So, I unwound the coil; it is 700 turns of AWG40 wire. I modeled it on a couple of different calculators and I got about...morzh — 12:29 PM |
Ron
From the conversation, it was my impression he was a pretty old dude who is looking to place his radios in good h...morzh — 12:16 PM |
Philco 49-1040
Yes, and it's surprisingly common for early TVs to be mostly or all original. My thinking is that they were retired ear...Bob Andersen — 11:59 AM |
91H Code 126 Restore
Hi Nick,
Usually the dashed lines connected to components means the part is a substitute in the circuit for specific ...RodB — 09:42 AM |
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM |
I'm pretty sure that the dotted line I circled in an earlier post signifies that it is applicable to the 226 model which...RealRider — 08:05 AM |
Philco 49-1040
Hello bob,
that underside looks like it is all original !
Sincerely Richardradiorich — 02:07 AM |
Philco 49-1040
Oh yes, many bumblebees and loktal tubes.
The cutout is for the speaker. Here's a photo from a different set.
Bob Andersen — 12:59 AM |
There are currently 4272 online users. [Complete List] » 2 Member(s) | 4270 Guest(s)
