Philco 84b confusion
The info I got says: 36 AWG wire/14.75 turns/lug 3 to ground/wind from top CC.
Looking for 2 ohms & 3.2 ohms. Does that sound right?
Sound good. Nowhere near 101 ohms.
Here’s the cabinet for the 84
Nice 2nd gen set! Worked on one last yr https://philcoradio.com/phorum/showthread.php?tid=20433 Here's a 1st gen set 1st gen Model 84 (philcoradio.com) The chassis are the  same.
Having been involved with steam locomotive restoration as well as radio refurbishment, radio is definitely the less taxing of the two. The common thread is that of returning something old to usefulness, while employing skills that are in danger of being forgotten. There’s a lot of satisfaction to be derived!
Rob, apologies, I forgot to comment in my last post how nice a condition that chassis is in and how nice your work looks. The spiral wrap around "in air" connections is a very nice touch!
Thanks! My wife found the spiral wrap. It works very well when covering wire that’s been soldered between parts.
Hi Guys- The 38 AWG wire came today so I’m (hopefully) back at the Philco 84. Are the transformer primaries (oscillator and antenna) wound in the same direction or the opposite direction from the secondaries? Inquiring minds………..  Thanks! - Rob
Hello Rob,
good news!
Eureka! Got the radio up and running. Still have to do an alignment and check some voltages. Thanks again for the help. It wouldn’t have happened without you! - Rob
P.S.- Antenna suggestions?
Hi Rob,
There's a thread from some time ago where members volunteered their successes on conventional and non-conventional antennae. I'm sure you can find it with a search. It is quite extensive.
You might be referring to this one?
https://philcoradio.com/phorum/showthread.php?tid=19673
Here's another.
https://philcoradio.com/phorum/showthread.php?tid=870
and one from my blog:
https://ronsradios.com/2020/08/29/give-y...-some-air/
Thanks Guys- I’ll play around with the different antennas and see how they perform. Yet another area for exploration! - Rob
91H Code 126 Restore
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
There are currently 4632 online users. [Complete List]
» 1 Member(s) | 4631 Guest(s)
