Philco 84b confusion
The info I got says: 36 AWG wire/14.75 turns/lug 3 to ground/wind from top CC.
Looking for 2 ohms & 3.2 ohms. Does that sound right?
Sound good. Nowhere near 101 ohms.
Here’s the cabinet for the 84
Nice 2nd gen set! Worked on one last yr https://philcoradio.com/phorum/showthread.php?tid=20433 Here's a 1st gen set 1st gen Model 84 (philcoradio.com) The chassis are the  same.
Having been involved with steam locomotive restoration as well as radio refurbishment, radio is definitely the less taxing of the two. The common thread is that of returning something old to usefulness, while employing skills that are in danger of being forgotten. There’s a lot of satisfaction to be derived!
Rob, apologies, I forgot to comment in my last post how nice a condition that chassis is in and how nice your work looks. The spiral wrap around "in air" connections is a very nice touch!
Thanks! My wife found the spiral wrap. It works very well when covering wire that’s been soldered between parts.
Hi Guys- The 38 AWG wire came today so I’m (hopefully) back at the Philco 84. Are the transformer primaries (oscillator and antenna) wound in the same direction or the opposite direction from the secondaries? Inquiring minds………..  Thanks! - Rob
Hello Rob,
good news!
Eureka! Got the radio up and running. Still have to do an alignment and check some voltages. Thanks again for the help. It wouldn’t have happened without you! - Rob
P.S.- Antenna suggestions?
Hi Rob,
There's a thread from some time ago where members volunteered their successes on conventional and non-conventional antennae. I'm sure you can find it with a search. It is quite extensive.
You might be referring to this one?
https://philcoradio.com/phorum/showthread.php?tid=19673
Here's another.
https://philcoradio.com/phorum/showthread.php?tid=870
and one from my blog:
https://ronsradios.com/2020/08/29/give-y...-some-air/
Thanks Guys- I’ll play around with the different antennas and see how they perform. Yet another area for exploration! - Rob
What should I offer?
I have an opportunity to acquire this radio-phono, but the owner wants me to make an offer.  Tried searching images, but...nocusr — 12:35 PM
I have an opportunity to acquire this radio-phono, but the owner wants me to make an offer.  Tried searching images, but...nocusr — 12:32 PM
I have an opportunity to acquire this radio-phono, but the owner wants me to make an offer. Tried searching images, but...nocusr — 12:29 PM
So, I unwound the coil; it is 700 turns of AWG40 wire. I modeled it on a couple of different calculators and I got about...morzh — 12:29 PM
Ron From the conversation, it was my impression he was a pretty old dude who is looking to place his radios in good h...morzh — 12:16 PM
Philco 49-1040
Yes, and it's surprisingly common for early TVs to be mostly or all original. My thinking is that they were retired ear...Bob Andersen — 11:59 AM
91H Code 126 Restore
Hi Nick, Usually the dashed lines connected to components means the part is a substitute in the circuit for specific ...RodB — 09:42 AM
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM
Philco 49-1040
There are currently 3817 online users. [Complete List]
» 1 Member(s) | 3816 Guest(s)
