I confused on model 38-12 resistors
To whomever can straighten me out please:
I'm confused on the color coding of the resistors in the 38-12. They seem to be a cross between the old dogbone color coding and the current codes (reading bands from one end) and they appear to be original.
Here they are:
#1 R18 in Riders
brown body w/white brown yellow bands current code says 910K; Riders shows 190K; my meter reads 218K
#2 R24 in Riders
lavender body w/black lavender black bands current code says 7 ohms; Riders shows 70 ohms; my meter reads 71 ohms.
#3 Riders doesn't show
yellow body w/black yellow green bands current code says 400K; my meter reads 3.93 meg
#4 Riders R9
brown body w/black brown green bands current code says 100K Riders shows 2 meg; my meters reads 3.03 meg
#5 Riders R11
yellow body w/black yellow orange bands current code says 4K; Riders shows 40K; my meter reads 76K
#6 Riders R13
green body w/brown green yellow(I think--could be orange) current code says 150K Riders says 51 K; my meter reads 62K
#7 Riders R5
green body w/ brown green orange bands current code says 15K; Riders says 51K; my meters reads 55K
THANKS FOR YOUR HELP.
For a nickel apiece I'd just replace them.
Please read:
http://www.philcoradio.com/tech/resistor.htm
The original resistors in the 38-12 will follow the color coding as explained under "A Word about Color Codes" on the page linked above.
You see one stripe at one end of a resistor, and another stripe in the middle, with the rest of the resistor body a third color, yes?
So, let's take each of your resistors in sequence...
#1. Brown body, white stripe on end, yellow stripe in middle = 1 9 0000 = 190K
#2. Lavender (violet) body, black stripe on end, black stripe in middle = 7 0 .0 = 70 ohms
#3. Yellow body, black stripe on end, green stripe in middle = 4 0 00000 = 4 meg
#4. Brown body, black stripe on end, green stripe in middle = 1 0 00000 = 1 meg. If it were a 2 meg resistor, it would have a red body.
#5. Yellow body, black stripe on end, orange stripe in middle = 4 0 000 = 40K
#6. Green body, brown stripe on end, yellow stripe in middle = 5 1 0000 = 510K. So that "yellow" stripe is probably an orange stripe, which would make it 5 1 000 = 51K.
#7. Green body, brown stripe on end, orange stripe in middle = 5 1 000 = 51K.
See, it isn't that difficult once you get used to the fact that what appears to be a second stripe is actually part of the resistor body color.
And, your first, second, third and seventh resistors are within 20% tolerance. The others are outside the permissible 20% tolerance and must be replaced.
Edit: I see Codefox posted as I was typing. I agree with his comment. Icon_smile
codefox1 Wrote:For a nickel apiece I'd just replace them.
I'm replacing them if necessary; just needed to understand the color code system before I did that. Would not be good to put 910K in as a replacement for 190K. Icon_eek
Thanks.
Thanks for your help Ron. I really appreciate it!!!!! Now to tackle that sole capacitor block in it. This set has been worked (hacked) on before.
Art
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
