Philco 48-1264
Any one know where you hook up the Fm antenna to this?
Skip
There is a little 4 pin socket on top of the RF front end chassis, between the AM antenna terminal strip and the 6BA6 IF tube. The schematic shows the pin connections for the mating plug of the in cabinet FM dipole.
https://philcoradio.com/library/download...8-1949.pdf
ok thanks hooked up antenna FM completely dead no noise or signals. AM works fine.
So either doing something wrong? or FM is bad.. Not sure what to check next.
Skip
ok started to go thru alignment procedure for Fm
Fm alignment steps 1 and 2. heard the 9.1 mhz signal.. did not adjust anything yet...had to use a strong signal. -3.5 dbm modulated.
went to next step sig generator to pin 4 j400 frequency of 105 mhz no signal heard at all..
Skip
OK Found problem... The 7F8 converter tube was loose in socket moved it around and FM started working.
So now onto alignment
Skip
What should I offer?
I am not sure what radio it is, but seems like a 1950 AM/FM set. Or from 1948, possibly one similar to 48-1264. In any ...morzh — 12:44 PM
I have an opportunity to acquire this radio-phono, but the owner wants me to make an offer. Tried searching images, but...nocusr — 12:29 PM
So, I unwound the coil; it is 700 turns of AWG40 wire. I modeled it on a couple of different calculators and I got about...morzh — 12:29 PM
Ron From the conversation, it was my impression he was a pretty old dude who is looking to place his radios in good h...morzh — 12:16 PM
Philco 49-1040
Yes, and it's surprisingly common for early TVs to be mostly or all original. My thinking is that they were retired ear...Bob Andersen — 11:59 AM
91H Code 126 Restore
Hi Nick, Usually the dashed lines connected to components means the part is a substitute in the circuit for specific ...RodB — 09:42 AM
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM
Philco 49-1040
Philco 49-1040
There are currently 3696 online users. [Complete List]
» 2 Member(s) | 3694 Guest(s)
