DATA DISCREPANCY PART N. 4231 FILTER CHOKES
Threads: 24
City: LAVERN-SUBIRATS
State, Province, Country: ESPAÑA
I have a model 20. The choke was open. According to the Philco catalog from 1936, the resistance is 400 ohms. According to the information that appears in the library in its CHOKES section, a value of 4,000 ohms appears. Which one is correct?
One way to fix it is to rewind. Or replace a resistor with the correct value of approximately 4W.
What do you recommend? It's not easy to rewind.
I appreciate any information. It is important to correct the value if there is an error in the library.
Threads: 271
City: Wilsonville
State, Province, Country: OR
OK, thanks for pointing that out. I'll alert Nathan who manages the library.
Threads: 24
Threads: 271
City: Wilsonville
Other folks will have to comment on whether a resistor of proper value would be OK, I don't know. As far as replacement, I have replaced a filter choke with a Hammond choke in one of my restorations and it went just fine. Here's a link to the discussion on the 66B restoration. Terry (radioroslyn) does suggest a resistor replacement as you'll read in the threads but I opted for the choke replacement.
Threads: 24
OK thank you very much
Regards,
Ferran
Threads: 268
The circuit in the 20 is different than the 66 in that the 20 the choke is all of the HV @ 50ma or so. In the 66 it's just used for about a few ma up in the mixer.
(This post was last modified: 02-01-2022, 07:06 PM by Radioroslyn.)
Threads: 271
City: Wilsonville
Thanks Terry, I wasn't clear. I didn't mean that the choke I used would be the one for the 20, just that the Hammond folks do have chokes that could be used as long as you select the right one.
Threads: 214
City: Seattle
State, Province, Country: WA
I looked back at the original source Philco parts catalogs.
Philco 1933 parts catalog:
Philco 1936 parts catalog:
All of the later Philco catalogs (1937, 1938, 1942) that we source from also say 400 ohms.
I'd say that 400 ohms the correct value. For the Library Chokes table I've updated it to be that value too.
Threads: 113
City: Omak
hello Guys,
If I remember I am fairly sure that it should be 400 because I believe that what my 20 is.
Threads: 24
This is the closest product I have found:
https://www.mouser.es/ProductDetail/Hamm...TtYRvn8nru
14H, 75mA, 429 ohm
I am concerned about the 75mA
Threads: 14
City: Irvington, NY
I would not be concerned about the 75 mA rating because the total power supply current drain of the model 20 is only 72 mA or less.
As shown in the attached service note chart, the total power supply current through the 80 rectifier is 36 ma per plate, for a total of 72 mA. The actual total plate current drain of the other tubes is only 48 Ma, the remaining current being dissipated in the bleeder resistor and associated circuits.
https://philcoradio.com/library/download...n%2036.pdf
Threads: 24
You are right. Thanks for the help. I will buy the choke.
Model 20 is one of my favorites.
Regards,
Ferran
What should I offer?
I am not sure what radio it is, but seems like a 1950 AM/FM set. Or from 1948, possibly one similar to 48-1264.
In any ...morzh — 12:44 PM |
I have an opportunity to acquire this radio-phono, but the owner wants me to make an offer. Tried searching images, but...nocusr — 12:29 PM |
So, I unwound the coil; it is 700 turns of AWG40 wire. I modeled it on a couple of different calculators and I got about...morzh — 12:29 PM |
Ron
From the conversation, it was my impression he was a pretty old dude who is looking to place his radios in good h...morzh — 12:16 PM |
Philco 49-1040
Yes, and it's surprisingly common for early TVs to be mostly or all original. My thinking is that they were retired ear...Bob Andersen — 11:59 AM |
91H Code 126 Restore
Hi Nick,
Usually the dashed lines connected to components means the part is a substitute in the circuit for specific ...RodB — 09:42 AM |
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM |
I'm pretty sure that the dotted line I circled in an earlier post signifies that it is applicable to the 226 model which...RealRider — 08:05 AM |
Philco 49-1040
Hello bob,
that underside looks like it is all original !
Sincerely Richardradiorich — 02:07 AM |
Philco 49-1040
Oh yes, many bumblebees and loktal tubes.
The cutout is for the speaker. Here's a photo from a different set.
Bob Andersen — 12:59 AM |
There are currently 4276 online users. [Complete List] » 2 Member(s) | 4274 Guest(s)
