philco 112 questions
ok I am working on my model 112-A with two 47's and i have a question it may seem dumb, but the condenser can part number 3489 from what i have read terminal 6 is grounded to the chassis and not to the can itself. what difference would it make if I chose not to rebuild the can and relocate the capacitors it looks to me that all the caps are grounded anyway as it looks in the drawing. it looks to me the better way is to rebuild the can this is just a question
ok my dial cord broke and i need a drawing i have spent hours trying to fix this and what size of cord do i need would a good quality fishing line work
benny
Benny, I merged the two 112 threads together. We like to keep a single thread for the same radio, it helps folks especially in the future when looking back at questions on a particular radio.
Don't know if this will help answer your cap block question but its an annotated schematic that Ron Ramirez prepared and is found in our library: See Model 112 (late) https://philcoradio.com/library/index.ph...chematics/
nothing there about the dial cord
you are correct, I have not found anything describing the dial strining but hopefully someone with a 112 will be able to help you out.
Does this help? Its a 112X.
That's the cleanest photo of the cord routing that I've seen. I have heard of braided nylon fishing line of about 40 pound strength being used. I haven't personally. If anyone has how did it work out for you? I think I would take the dial off when re-stringing. Take care and BE HEALTHY! Gary
yes, thank you now dose anyone what terminal the 0.01 and the 0.15 caps go on the tone control
benny
Benny, this is what I use for Philco dial cords   1.7mm 400lb made with Kevlar BLACK Braid Speargun Band Constrictor Cord 30ft | eBay    I have used it for a 118 and an 89, worked perfectly for both. The 89 was a very similar setup to your 112.
M R Radios   C M Tubes
Benny - there's some close up photos of the dial cord in my 112 restoration thread:
https://philcoradio.com/phorum/showthrea...851&page=2
thank you that was the help i needed those are some good photos of the dial string and thank you Steve that dial cord worked excellent
benny
What should I offer?
I am not sure what radio it is, but seems like a 1950 AM/FM set. Or from 1948, possibly one similar to 48-1264. In any ...morzh — 12:44 PM
I have an opportunity to acquire this radio-phono, but the owner wants me to make an offer. Tried searching images, but...nocusr — 12:29 PM
So, I unwound the coil; it is 700 turns of AWG40 wire. I modeled it on a couple of different calculators and I got about...morzh — 12:29 PM
Ron From the conversation, it was my impression he was a pretty old dude who is looking to place his radios in good h...morzh — 12:16 PM
Philco 49-1040
Yes, and it's surprisingly common for early TVs to be mostly or all original. My thinking is that they were retired ear...Bob Andersen — 11:59 AM
91H Code 126 Restore
Hi Nick, Usually the dashed lines connected to components means the part is a substitute in the circuit for specific ...RodB — 09:42 AM
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM
Philco 49-1040
Philco 49-1040
There are currently 3780 online users. [Complete List]
» 1 Member(s) | 3779 Guest(s)
