Philco 16B
Looking for a readable schematic and parts list .. copies i have are very hard to read. this one uses a 80 rectifier tube
[Image: https://live.staticflickr.com/65535/5189...88b7_k.jpg]
[Image: https://live.staticflickr.com/65535/5189...ba34_k.jpg]
Thanks
Skip
https://philcoradio.com/library/download...l.%201.pdf
It's a code 121.
Thanks Terry, Have you ever worked on this model?
There is a hole on right side of cabinet.. Was that factory? If so what went there?
Skip
Vecher, if you look in the gallery of the main site,  https://philcoradio.com/gallery2/1933b/#Model_16B   , you see that the description of this model says it has a squelch control which was turned on and off by a switch on the side panel, and controlled by a potentiometer on the back of the set.
Yes, Philco calls it the QAVC switch #54 on the diagram. I think your tuning shaft is missing a threaded hole in it's center.
Some 16B sets used a tuning knob with a set screw on the side. These will not have the drilled and tapped tuning shaft.
Have No clue to what you guys mean ...
Skip
I don't know that I've seen a rosette knob w/ a set screw in the side. I have in the front and hex w/a screw in the side.
Skip,
On the early 16B'B the two speed tuning mechanism requires that you pull the tuning knob out or push it in to change speeds. Most of the knobs have a spring steel clip that holds them onto the shaft. On this sets it needs screw to hold the knob in place. When you use a non set screw knob it will pull off. If you look closely at the 2nd gallery pic you'll see a hole in the tuning knob. That one is missing the screw. The later model sets w/ hex knobs had a small set screw in the knob.
YMMV
Questions about Chuck have been moved into their own thread.
Gloritone 27 Radio
Another make I have seen from U.S Radio and Television was Apex Electric, or U.S Apex, the badge on some of those had a ...Arran — 12:56 AM
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
