Philco PT10 - Need pictures
I have a PT10 Philco that has been mauled by someone.  Wires have been cut or disconnected and some of the caps have been removed.  All the coils, transformers, field coil, and output transformer all  check out ok so I think this radio could be restored.  I have the schematic but it would really help if I could get a few detailed pictures of the underside and top of the chassis.
Thanks, Bob
Bob, drop down to the bottom to the Philco Radio Library. 1941 service manual and schematic available there. Take care and BE HEALTHY! Gary
Like this: https://philcoradio.com/library/download...20Book.pdf
If the wires aren't cut short you maybe able to tell where they go. Since it's a '41 set you mize well rewire it. A lot of it going to be intuitive just from placement. Keep your leads short as possible and neat. Somewhere around there is a Philco color code list which could be helpful to sort pri 2ndy on the IFTs.
Rf and osc coils the ohm meter is going to be your friend to determine the pri/2ndy. Then trial and error.
I had a 40-2** console that was given to me that was in a similar condition. I really went back together pretty easily. Kinda backwards from what we do most of the time...
This is the replacement guide for transistors by GE parts. So, GE-3 is your power replacement for AR14 Just ...morzh — 04:57 PM
Philco 91 Restore Code ??
How do I know if AVC is OK? For the compensator cap I settled on 330pf. Its much closer now and close enough for me. I ...dconant — 04:46 PM
If the small signal ones, take any Ge transistor with unity gain good enough and Vce max 30 or so V. For the output....y...morzh — 03:43 PM
Yes, Michael. This winter I repaired this Westinghouse, RCA 121 and Zenit 5S29. All that remains is to veneer the Zenit ...RadioSvit — 03:28 PM
Thank you. I have one board completely de-populated. Just looking for the correct values. I'll let you know. Still h...R3Sons — 03:13 PM
Is this the one from the Fall Kutztown 2023?morzh — 02:59 PM
If it does not get narrower with strong signal and your AVC is OK, it could veru well be that the shadowgraph's magnet i...morzh — 02:58 PM
The width does not get narrower with generator. I think I will try some other cap values.dconant — 02:56 PM
410pF is a large capacitance to parallel to a compensator. As for the shadowmeter....yes, 3/8" is a bit wide, bu...morzh — 02:49 PM
My new nostalgic video... My weekly video on radio history Who is interested - come, watch, critically evaluate the qu...RadioSvit — 01:47 PM
There are currently 3944 online users. [Complete List]
» 1 Member(s) | 3943 Guest(s)
