Threads: 570
Greg
For the magnetic tuning to work you will need to align it too. Or it will not.
I mean, of course after you fix all the switches and such.
Threads: 24
City: Whitehall PA
I'm confused by the switch marked part #135. It seems to short, I believe, the discriminator outputs (A & B) together, but not ground them as switch #93 does.
I have no idea where part #135 is located. Is it part of the dial mechanism? It's not the light switch portion of #93, the schematic shows that "linked" to the magnetic tuning switch.
Greg O.
Whitehall, PA
Threads: 24
City: Whitehall PA
Part #135 confusion gone. It is part of the dial mechanism. Google "found this":
See https://worldradiohistory.com/Archive-Ri...hanges.pdf (page 13 of file):
It will be noticed in the schematic
on page 7-31, 7-32 of Rider's Volume
VII, that two parts carry the same
number: No. 135. One is the pilot
light and this is the correct number for
this part; the 'second is a switch, lo-
cated on the schematic just below and
to the left of the 6J5G AVC tube.
The number of this switch should be
137. This number does not appear in
the list of parts on page 7-36, but the
switch is used on the automatic dial
mechanism and appears in the parts
list under "Code 122" as " Plunger
Stop and Switch Assembly, Part No.
45-2330."
I thought something wasn't right about that.
Now something else to check. Hopefully something easier to access.
Greg O.
Whitehall, PA
Threads: 24
City: Whitehall PA
I'm curious. How accurate are these radios' dials after alignment?
For example, I aligned the 7.35-11.6 MHz band at 11.0 and 7.5 as per the instructions. I then looked to see where 10 MHz landed on the dial. It shows up at ~10.015 MHz. Not bad, not perfect. I figured I'd check 10 MHz since the 31m SW stations are around there along with WWV.
Greg O.
Whitehall, PA
Threads: 114
City: Sneedville, TN
That's well within tolerances, as far as my experience goes. You might be able to get it a hair closer, but I wouldn't fret it as long as your sensitivity is good. I generally try to get it within one "tick" + or - on the dial with any radio, and sometimes that takes a LOT of fiddling and repeating the alignment procedure. The RCA C9-4 I just completed I went over, and over, and over about 6 times before I had it both accurate and sensitive enough to meet my expectations. If it is sensitive, and works as well as you like, I would not worry any more. Sometimes it is best to leave well enough alone.
Threads: 24
City: Whitehall PA
DONE... Talk about a glacial pace!
Well electrical part was done for quite some time. I just had to replace the grill cloth and put it all back into the cabinet.
It sounds really good.
Greg O.
Whitehall, PA
Threads: 114
Congratulations, Greg ! Pictures of the finished radio?
Threads: 24
City: Whitehall PA
OK - by popular demand, a picture  .
The cabinet's in pretty decent shape. I cleaned it and applied some wax.
I still need to make some station tabs. I have an old dial I'll carve up into tabs. The plan is to cut out the tabs, make decals with the call letters on them, apply them to the tabs and coat them with something, lacquer/polyurethane...
The sound quality is really good. I need an antenna. There's just a short piece of wire hanging off of the back now (that sad, white wire curled up on the ground).
I have a TV I'll probably finish next. Then it's probably on to the 37-690 whose cabinet is sitting in our dining room. It's way to heavy to move to the basement.
Greg O.
Whitehall, PA
Threads: 416
City: Boston
Nice, looks sharp. Will sound super with antenna.
Threads: 155
City: Westland, MI
I'd be very proud to own that set. If that is where you intend to keep it you can tuck a longwire antenna in between the kick moulding and the carpet along the walls. You'll never see it! Take care and BE HEALTHY! Gary
Threads: 114
It's beautiful, Greg ! Congratulations again, my friend.
Threads: 97
City: Poughkeepsie, N.Y.
Beautiful radio enjoy it for years to come!
Users browsing this thread: 18 Guest(s)
Thank you very much. I'll let you know how it goes.R3Sons — 11:00 PM |
Hello mike,
Nice job hopefully it works and I am sure it will.
Sincerely Richardradiorich — 09:15 PM |
Hello Peter,
I am glad you got the radios and I too have that same zenith in my collection !
I am also waiting for the...radiorich — 08:52 PM |
So, I sat down, and first tried 40 AWG wire. It broke quickly. I retook diameter: this one was 0.05mm whereas the one I ...morzh — 08:24 PM |
This is the replacement guide for transistors by GE parts.
So, GE-3 is your power replacement for AR14
Just ...morzh — 04:57 PM |
Philco 91 Restore Code ??
How do I know if AVC is OK?
For the compensator cap I settled on 330pf. Its much closer now and close enough for me. I ...dconant — 04:46 PM |
If the small signal ones, take any Ge transistor with unity gain good enough and Vce max 30 or so V.
For the output....y...morzh — 03:43 PM |
Yes, Michael. This winter I repaired this Westinghouse, RCA 121 and Zenit 5S29. All that remains is to veneer the Zenit ...RadioSvit — 03:28 PM |
Thank you. I have one board completely de-populated. Just looking for the correct values. I'll let you know. Still h...R3Sons — 03:13 PM |
Is this the one from the Fall Kutztown 2023?morzh — 02:59 PM |
