RCA model 211K parts list needed
Anyone have a parts list for an RCA model 211k?
I only see 3 filter caps on the schematics and the can mounted on the chassis lists 4.
Values are a little different on the can, so I am guessing this can was replaced at some point?
Does not hum when played, so maybe I can leave the filter caps alone?
murf
https://worldradiohistory.com/ARCHIVE-RC...1942-C.pdf
look at page 782-C (page 799 of the PDF) The RCA schematic, very clear, is just before it, as is the alignment information, etc.
Never mind guy's,
No parts list available for this model.
Just have to get it off the schematic I guess.
Sorry.
murf
Yes, there is - Mike gave you the answer (post #2, above).
Had a hard time with the link Mike sent, so I just worked off the schematic.
Thanks for Mikes time spent looking that up.
murf
Murf, are you familiar with using PDFs? That link takes you to volume C of the RCA information. What you want, the parts list is on page 799 of the PDF. Just enter that in the little window at the top of the viewer where the page numbers show up, and hit enter. The PDF is a rather long file, so it won't load completely right at once, but will take several minutes, depending on your download speed. There is a lot of other useful information there, so I hope you figure out how to use PDFs with your browser. Of course, it does work best with a regular desktop of laptop with a full screen rather than trying to use a telephone or tablet.
The home site from which that information comes is: https://worldradiohistory.com/index.htm
The RCA service information is found on the files here:
https://worldradiohistory.com/RCA-Victor-Service.htm
I hope you can master how to download and use the PDFs available from this site. They really are a valuable resource, not just for RCA service information, but for radio in general.
Got it Mike.
Thanks for the info.
murf
Philco 91 Restore Code ??
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 6491 online users. [Complete List]
» 2 Member(s) | 6489 Guest(s)
