Philco 84 field coil wire size
Hello,
I have a bad field coil on my Philco 84 and will try rewinding it. I was able to get the field coil assembly apart and access the coil itself but am not sure of the wire gauge size. I think it might be 35 gauge but would like to know if anyone knows for sure?
Regards,
Ctkid
From what I can tell the coil is rated for 40ma. 35G is good for 42ma as per The Radio Amateur's Handbook 1956 edition
The wire size can be measured with a mechanical micrometer or caliper. Allow a couple of thousands for the film insulation.
Pliny the younger
Thanks for your responses!
I don't know, 40 ma seems kind of low for a set with a #42 output tube, the #80 rectifier tube is rated for 125 ma I think. I would try measuring the actual wire used in the field coil. Of course I am assuming the the field coil in the model 84 is used as a filter choke in the positive side of the B+ circuit, and not in the negative side on the bias supply, which would require a lower current rating.
Philco spec the coil at 40ma for that K speaker.
The speaker used in Model 84 is type SB (not a K) and it has an 1140 ohm field coil rated at 50 mA.
(source: the Philco Speakers spreadsheet, downloadable at this link on this site.)
Hi Richard. Yes, we are waiting for warm weather. I have more than a dozen hulls waiting to be painted.RadioSvit — 11:06 AM
Then it is even easier. Yep, my GE guide also says "Silicon".morzh — 09:43 AM
Mike, according to my ECG replacement guide, the AR107 & AR108 both cross reference to a ECG 123A as does a GE-10. T...462ron — 09:41 AM
The 66 Ohm filter in the 1st detector's plate circuit. Look in the early version sch. Here it is, the spiral that ma...morzh — 09:11 AM
Ron yes, that was found. The problem is trying to find GE-10 for AR107/108. I could not find even mentioning of it. ...morzh — 09:06 AM
Your output transistor X6 cross references to a GE-3 transistor and I’ve used that before. There are a few here on eBay…...462ron — 07:58 AM
Mike; Where was this RF choke located? I remember seeing on a few sets that had detector-amplifiers ahead of the powe...Arran — 02:29 AM
Thank you very much. I'll let you know how it goes.R3Sons — 11:00 PM
Hello mike, Nice job hopefully it works and I am sure it will. Sincerely Richardradiorich — 09:15 PM
Hello Peter, I am glad you got the radios and I too have that same zenith in my collection ! I am also waiting for the...radiorich — 08:52 PM
There are currently 3769 online users. [Complete List]
» 4 Member(s) | 3765 Guest(s)
AvatarAvatarAvatarAvatar
