Speaker plug
I need to replace the female socket on my 38-116. I can't find anything that fits. I would replace the male plug on the speaker if I could find a pair of five pin plugs that i could attach the male end to the speaker frame like the old one. any thoughts?  Thanks   Frank
Hello Frank,
maybe post a photo of the mating side because I have lots of connectors like that .
sincerely Richard
Check radiodaze, they might have something you could make work!
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
Does it look like this    https://www.ebay.com/itm/284722368985?ha...SwUjtiPHrJ
M R Radios   C M Tubes
Steve Davis...Yes that's it. don't know if I can get the wires unsoldered and out.. Need new harness. Old insulation is crumbling. Frank
Picture of plug and socket
Hello Quick,
I have a very similar plug on my General Electric 1940 Console my wire was also bad, so I used heat shrink and spliced modern wire on it for now than when get time I am going to drill out that rivet in the middle .
Rich, the riveted disk is in bad shape. If I can't find a good used socket I will take your advice.  Thank you, Frank
Hi Richard. Yes, we are waiting for warm weather. I have more than a dozen hulls waiting to be painted.RadioSvit — 11:06 AM
Then it is even easier. Yep, my GE guide also says "Silicon".morzh — 09:43 AM
Mike, according to my ECG replacement guide, the AR107 & AR108 both cross reference to a ECG 123A as does a GE-10. T...462ron — 09:41 AM
The 66 Ohm filter in the 1st detector's plate circuit. Look in the early version sch. Here it is, the spiral that ma...morzh — 09:11 AM
Ron yes, that was found. The problem is trying to find GE-10 for AR107/108. I could not find even mentioning of it. ...morzh — 09:06 AM
Your output transistor X6 cross references to a GE-3 transistor and I’ve used that before. There are a few here on eBay…...462ron — 07:58 AM
Mike; Where was this RF choke located? I remember seeing on a few sets that had detector-amplifiers ahead of the powe...Arran — 02:29 AM
Thank you very much. I'll let you know how it goes.R3Sons — 11:00 PM
Hello mike, Nice job hopefully it works and I am sure it will. Sincerely Richardradiorich — 09:15 PM
Hello Peter, I am glad you got the radios and I too have that same zenith in my collection ! I am also waiting for the...radiorich — 08:52 PM
There are currently 3283 online users. [Complete List]
» 3 Member(s) | 3280 Guest(s)
