question about a Philco Tropical Model
Threads: 1
City: ATHENS
State, Province, Country: GREECE
Threads: 271
City: Wilsonville
State, Province, Country: OR
Threads: 271
City: Wilsonville
It would appear based on the fact that the turn table was made in England (assuming the turn table is original to the set) that the entire set was probably made there rather than in the US. Unfortunately we don't have much information on Philco Tropics made in England. Hopefully someone on the Phorum will be able to provide you with some additional information. If you had a photo of the back of the radio chassis, there is often a label or plate with model number information on it.
Threads: 28
City: Wellborn Florida
Voltage and Hertz would be right for Greece if it is a English made set. 1948-1950 time frame is when England starting using the wall outlet and plug they use today please post a picture of the plug on the power cord which should be 2 round pins for Greece. Welcome to the Phorum
If the unit still has its original back, it should have a model number printed on it. It will likely be four numbers, preceded by an A or a B - for example, A.1234 or B.2345.
If you can share this information with us, we might be able to track down something if it is available.
Unfortunately, service (and other) information for British-made Philco Tropic receivers is not always available anywhere, not even on the UK Vintage Radio Repair and Restoration forum.
Threads: 1
City: ATHENS
Thanks you so much for your welcome Ron and David! yes the unit still has its original back, and the model number printed on it is A. 3661. Its definitely made in Britain.
The plug on the power cord is not the original. The present has 2 round pins as the model has been in Athens, Greece since the early 50's (as far as we know). 1948-1950 time frame seems possible?
All the best,
Evangelos
Threads: 1
City: ATHENS
Thank you for your welcome to the Phorum Ron and David.
The unit still has its original back and the model number printed on it is A.3661. The original plug on the power cord does not exist anymore. The present has 2 round pins as the the unit was in use in Athens, Greece since the 1950's (as far as we know). 1948-1950 time frame seems possible?
All the best,
Evangelos
Thank you for furnishing the model number.
The UK Vintage Radio Repair and Restoration group issued a DVD filled with schematic diagrams and service information for many British-made radios. I have a copy of this DVD and I looked. Unfortunately, your model is not listed in this DVD set.
I am sorry I cannot help you further on this subject.
Threads: 110
City: Omak
State, Province, Country: WA
Hello Evangelos,
Welcome how exciting is this it is nice to see someone here from Greece !
Threads: 1
City: ATHENS
Thank you Ron, for your generous help! Hello Richard, greetings from Athens!
All the best,
Evangelos
Philco 91 Tuning Condenser
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM |
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
Welcome to the Phorum, R3Sons! I have very limited experience with car radios other than installing custom radios back ...GarySP — 01:08 PM |
OK, I need to rename this thread to say..Eico 368 TV/FM Sweep Generator instead of the current title..Heathkit Sweep Gen...462ron — 12:49 PM |
There are currently 9379 online users. [Complete List] » 2 Member(s) | 9377 Guest(s)
