Resistance for Philco 112 push pull input transformer
Hello, does anyone know what the primary and secondary resistance should be for the push pull input transformer (#53 on schematic) for a Philco model 112?
I looked in a few different Philco parts catalogs, and they do not give the resistance, only the turns ratio (1:4).
The speaker table error?
Philco 70 antenna lead
