Can anyone identify this TV/Radio/Record Player Console??
Can anyone find the model of this unit?  (Photos Attached).
I've scanned the gallery and could not find it - it seems to be from the late 1940s.
I'm in the Detroit, Michigan, USA area.
TomC
One of them Philco 50-T-xxx consoles.
50-T-1477 seems to use exact same Radio/TV part.
https://www.earlytelevision.org/philco_50-t-1477.html
Welcome to the Phorum!
Icon_wave
Welcome Tom! Nice to have another Michigan connection. Take care and BE HEALTHY! Gary
There are currently 9660 online users. [Complete List]
» 1 Member(s) | 9659 Guest(s)
