Model 38-7 lamp replacement
Is there any way to replace the dial lamp on a Model 38-7 without disassembling the tuner dial assembly?
It looks like the lamp has to be removed and reinserted from inside the tuner dial.
Any suggestions?
Thank you,
Don
I suspect that the lamp holder snaps into the dial housing. If you push on the side of the lamp holder or pry between the dial housing and lamp housing. Push or pry gently. It should pop out if it's mounted in that fashion.
Thanks, Terry. I'll give that a try.
Don
Terry,
I was not able to remove the lamp socket. As unlikely as it seems, the socket appears to be an integral part of dial housing; not a separate piece. Any other ideas?
I am reluctant to try disassembly of the dial housing without assembly details and/or instructions. Service Bulletin #282 may have what I need but it is missing from the list of downloadable docs. Any idea where I might get a copy of this bulletin?
Thank you,
Don
Chuck Schwark's PhilcoRepairBench.com has some information on the tuning dial that might be helpful.
https://www.philcorepairbench.com/cone-c...ning-dial/
and Chuck has a link on that page to at least a portion of the 282 bulletin.
https://www.philcorepairbench.com/wp-con.../SB282.pdf
Hi Don
I when down to the heap and found a conecentric dial chassis. Replacing the lamp is easy...
Step1 Remove bezel by pushing it in turning it. It turns just a little.
#2 Remove dial pointer by pulling up. It has a flat on it so don't turn it.
#3 Remove wire ring that holds dials in place.
#4 Remove dial.
#5 Remove lamp.
Thank you Bob and Terry.
Terry, your tips are just what I need to get it apart w/o destruction.
Don
Gloritone 27 Radio
Oops, sorry. I've answered a question no one asked. :)morzh — 02:13 PM
Gloritone 27 Radio
To clear things up a bit. The Philco pot (33-5040) is single gang 3 terminals with AC switch. The picture shows how my p...dconant — 01:52 PM
Gloritone 27 Radio
The 20 pot has two sections: one is the Antenna attenuator, the other is the cathode bias one.morzh — 12:11 PM
Gloritone 27 Radio
Does the Philco pot have only 1 element (2 or 3 terminals) or is it ganged (5 or 6 terminals)? You state that one con...MrFixr55 — 11:52 AM
Gloritone 27 Radio
Yep. It is a light version of Philco 20. I guess it was soon after the 24 tube appeared on the market and everyone start...morzh — 11:04 AM
Gloritone 27 Radio
Hello guys, Well i just looked at my Gloritone and low and behold it is a model 27 !! Yes, Mr Fixr55 I have couple Sea...radiorich — 10:54 AM
Gloritone 27 Radio
It sure looks to me like someone was working off two schematics. I have been checking every part and wire with both sche...dconant — 10:51 AM
Gloritone 27 Radio
Hi dconant. I have not worked on the 27 but have worked on the somewhat similar Gloritone 26 for a friend.  These are...MrFixr55 — 10:41 AM
Gloritone 27 Radio
Hello dconant. You can also use film capacitors !! Maybe someone was working off of two schematics. It sounds like yo...radiorich — 10:02 AM
Philco circuit master 7004
If you are trying to sell this item, there are rules here about that. It needs to go to "For sale or trade", ...morzh — 08:41 AM
There are currently 3618 online users. [Complete List]
» 1 Member(s) | 3617 Guest(s)
