Philco 89 Questions
It sounds like someone took some liberties with your radio.
Pin 4 of the 77 is the suppressor grid and should connect to ground.
Pin 5 of the 77 is the cathode and should connect to the top of the oscillator tickler coil per the schematic.
If I were you, I would change the wiring to correspond with the schematic.
Yes I will thank you Ron.......................
Jim
Spring Lake MI
Resolved the wiring on the #77 tube and it made a world of difference, can receive station across the dial. Will do an alignment, I am getting a lot of whistling and vibration in the speaker on certain frequency's. Hope the alignment will solve that.
Jim
Spring Lake MI
After an alignment I noticed that from about 1000 kHz and lower freq. the reception will work at times or not. Above 1000 kHz does not fail can always receive.
I had a VOM lead connected to chassis with meter on, with the other probe I would touch the #2 pin (plate) of #77 tube and make it (lower freq's) come and go. Also on the OSC coil I could touch pin #5 (to tuner) and it will cut out, touch pin #4 it will cut in, this is all to do with the lower freq's. If I touch pin #1 or pin#2 has no effect (tickler). Touching pin #3 will also make it cut out.
I don't know if this is a tube (#77) problem or the OSC coil or what.
I have a 6200 ohm resistor to ground instead of an 8000 ohm on the tickler coil.
I have rewound the tickler coil on the OCS coil it was open.
Jim
Spring Lake MI
Finally got this guy up and running. As I said it would work on high freq's and some times on lower freq's. I tried bonding all grounds, replace the OSC cathode resistor back to 8.2K no help. Finally I cleaned the 77 tube socket and replaced the 77 tube after cleaning the pin of the tube. WALA it now works, I am one happy camper.
Thanks for the help.
Jim
Spring Lake MI
Gloritone 27 Radio
Oops, sorry. I've answered a question no one asked. :)morzh — 02:13 PM
Gloritone 27 Radio
To clear things up a bit. The Philco pot (33-5040) is single gang 3 terminals with AC switch. The picture shows how my p...dconant — 01:52 PM
Gloritone 27 Radio
The 20 pot has two sections: one is the Antenna attenuator, the other is the cathode bias one.morzh — 12:11 PM
Gloritone 27 Radio
Does the Philco pot have only 1 element (2 or 3 terminals) or is it ganged (5 or 6 terminals)? You state that one con...MrFixr55 — 11:52 AM
Gloritone 27 Radio
Yep. It is a light version of Philco 20. I guess it was soon after the 24 tube appeared on the market and everyone start...morzh — 11:04 AM
Gloritone 27 Radio
Hello guys, Well i just looked at my Gloritone and low and behold it is a model 27 !! Yes, Mr Fixr55 I have couple Sea...radiorich — 10:54 AM
Gloritone 27 Radio
It sure looks to me like someone was working off two schematics. I have been checking every part and wire with both sche...dconant — 10:51 AM
Gloritone 27 Radio
Hi dconant. I have not worked on the 27 but have worked on the somewhat similar Gloritone 26 for a friend.  These are...MrFixr55 — 10:41 AM
Gloritone 27 Radio
Hello dconant. You can also use film capacitors !! Maybe someone was working off of two schematics. It sounds like yo...radiorich — 10:02 AM
Philco circuit master 7004
If you are trying to sell this item, there are rules here about that. It needs to go to "For sale or trade", ...morzh — 08:41 AM
There are currently 3638 online users. [Complete List]
» 1 Member(s) | 3637 Guest(s)
