  • 1 Vote(s) - 5 Average
41-608. 121 bol
Well  I been away to long
Decided to work on my 41-608 122
It worked before I changed caps
Even after I changed electorlyitics
Now I changed paper caps   But not the 1000 volt caps   now nothing dead   At my Veriac 120 v
But at block and on off switch has 7v. Even if I jump switch out
Thanks sam
If you don't have it at the switch. Check your cord and plug. That set is a little odd as the switch is before the block most are after.
Thanks Terry
Plug was not making good contact in my veriac
Plugged it in wall now working
Thanks sam
HI SAM!
HI Sam Icon_wave
Restoring Philco 96
Have just bought this. The field coil tested at 3.18K. The cone has one small tear. I think this is what I need. Not ...morzh — 06:22 PM
91H Code 126 Restore
Well I am making progress with my first Philco.  It took a bit to figure out the on/off/band switch and tone control nei...RealRider — 01:33 PM
Interesting design in that the plate circuits of the first detector and IF stage take full B+ right from the filament of...462ron — 08:44 AM
Hello mike, that is lucky that you were able to do that ! I have one of my radios that the volume control is getting s...radiorich — 12:18 AM
That one cannot be taken apart well. It is riveted. But the domed switch luckily has some spacing (not much and not inte...morzh — 09:44 PM
Hello Mike, that D5 is great for switches and I do the same I will try spraying it through a side hole first before tak...radiorich — 09:38 PM
Almost decided ot turn it on, but didn't like the power switch being 50 - 100 Ohms, so it is the same exact switch as in...morzh — 08:56 PM
Philco 49-1040
+1 Bob. Yeah, they bought it in 1949 or so, but by 1960, with the CRT starting to dim and after having the set repaired...MrFixr55 — 04:41 PM
Hi Richard. Yes, we are waiting for warm weather. I have more than a dozen hulls waiting to be painted.RadioSvit — 11:06 AM
Then it is even easier. Yep, my GE guide also says "Silicon".morzh — 09:43 AM
There are currently 3709 online users. [Complete List]
» 3 Member(s) | 3706 Guest(s)
