Philco 89B Replacement Capacitors
Threads: 1
City: Palmyra
State, Province, Country: VA
Hello,
I was an electronic technician in my early career, but leaned more to an engineer career and mechanical hobbies as time has gone on. Repaired a couple radios when I was younger, but skills are rusty and stock of parts is low. I picked up a philco 89B in great original shape at a local auction and am kicking around the idea of overhauling it. Do you guys know anyone that would sell a "kit" of modern replacement caps needed for an 89B overhaul? Any suggestions would be greatly appreciated.
Scott
Threads: 155
City: Westland, MI
Welcome to the Phorum Scott! Sal's Capacitor Corner ( www.tuberadios.com) is a good source for replacement caps, as is Mouser Electronics. You can customize your order to the radio, or buy re-cap kits to have extras for the radios to come. Take care and BE HEALTHY! Gary
Threads: 417
City: Boston
Sal Brisindi is a good guy and member of NJARC, a good supporterr of the hobby.
Threads: 11
City: Greenlawn
State, Province, Country: NY
Hi RST, welcome to the Phorum. Lots of expert help to be found here.
Not to be a bummer, but the 89 and several other of that generation are somewhat notorious. the 2 biggest issues with this radio are open windings on the RF Amp output transformer primary (This transformer is between the RF Amp and 1st Detector), and the oscillator (tickler) winding of the 1st detector transformer. The other issue is the "Autodyne"1st detector circuit itself. This is not the very stable "Pentagrid Convertor that was released by RCA around this time, it is an older style, that is very finicky IMHO. leakage caused by moisture, dirt, etc. in the coils, trimmer caps and the tuning cap itself will stop the circuit from oscillating. Lots of good info, especially by Ron Ramirez on rewinding these coils and troubleshooting failure of this stage to function.
To the best of my knowledge, no one makes a specific "Kit" of caps specific to that radio, but the vendors already recommended to you are great sources.
Good luck with the radio and keep us all posted on your progress. I just got one of these working, but listen to the experts before me because I am still mad at the blasted thing!
John, MrFixr55
Threads: 570
Sal is good. Mouser is good.
Since you need to replace every paper cap, order all of them.
I forgot if 19/89 use backelite block caps, if they do - simply go to the book or sch and order the types and qtys you need.
Better yet, figure out if you also need resistors (mreasure in-circuit, good enough) and order all at once; this is where Mouser comes handy.
Hello mike,
that is lucky that you were able to do that !
I have one of my radios that the volume control is getting s...radiorich — 12:18 AM |
That one cannot be taken apart well. It is riveted. But the domed switch luckily has some spacing (not much and not inte...morzh — 09:44 PM |
Hello Mike,
that D5 is great for switches and I do the same I will try spraying it through a side hole first before tak...radiorich — 09:38 PM |
Almost decided ot turn it on, but didn't like the power switch being 50 - 100 Ohms, so it is the same exact switch as in...morzh — 08:56 PM |
Philco 49-1040
+1 Bob. Yeah, they bought it in 1949 or so, but by 1960, with the CRT starting to dim and after having the set repaired...MrFixr55 — 04:41 PM |
Hi Richard. Yes, we are waiting for warm weather. I have more than a dozen hulls waiting to be painted.RadioSvit — 11:06 AM |
Then it is even easier.
Yep, my GE guide also says "Silicon".morzh — 09:43 AM |
Mike, according to my ECG replacement guide, the AR107 & AR108 both cross reference to a ECG 123A as does a GE-10. T...462ron — 09:41 AM |
The 66 Ohm filter in the 1st detector's plate circuit.
Look in the early version sch.
Here it is, the spiral that ma...morzh — 09:11 AM |
Ron
yes, that was found. The problem is trying to find GE-10 for AR107/108.
I could not find even mentioning of it.
...morzh — 09:06 AM |
There are currently 2581 online users. [Complete List] » 1 Member(s) | 2580 Guest(s)
