Help identify a Philco Record Player
New here - be kind, please....
I've spent a good deal of the last couple of days searcing this forum and associated areas of the sight without any luck. I'm trying to find out the model umber of a Philco labeled record player that seemigly has no visible model number anywhere.
I have yet to learn how to post pics yetso I'm going to try and describe the player and hope someone can shed some light on it for me.
It's a record player only.
Low profile, Primarily grey in color and looks like plastic/bakelite.
Seems to be a 3 speed model.
Two raised Gold dials on the top front edges left and right.
Has a 45 RPM record stacker and an arm to steady stacked abums.
Rounded edges give it a 50's/60's look.
Philco label on the front center and the words "equipped with Diamond Needle" on the right front.
About the best I can do - couldn't find it in the "Gallery" here or anywhere on the internet.
any help would be appreciated....Thanks.
Hi,
I apologize for missing your post before now.
Directions for posting photos may be found here.
http://www.philcoradio.com/phorum/showthread.php?tid=29
http://www.philcoradio.com/phorum/showth...p?tid=4371
If it's a three speed phono, it was most likely made between 1950 and 1956.
Philco 91 Restore Code ??
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 6127 online users. [Complete List]
» 1 Member(s) | 6126 Guest(s)
