Philco 51-930 dial pointer what lubricant to use
Hello Everyone,
I am back working on my Philco model 51-930 My big question of the Day is what type of grease should I use to lubricate the area where the pointer scale rides alone as you can see in the photo below .
my first thought was white lithium and the other grease that i have on hand is super lube and last is good old Phone lube.
So what is your thoughts ?
i would try paste wax or silicone spray applied with a brush. grease will dry out and attract dirt. or nothing at all. is there a problem? pioneer receivers of the 70's used a plastic "shoe'' inside the pointer cavity. the dimples are the only contact areas and shouldnt develop much friction
Hello falcon,
there was grease but I cleaned it off it was a mess and gumming up the dial pointer .
have you tried it dry?
I use a very thin coat of silicone grease. Squeeze a dab on the end of a finger then wipe around the edge.
I've had good luck cleaning it really really well, then polishing the point of contact with 00 steel wool and a dremel to an almost mirror shine. Smooth as butter after that.
Hello Guys,
Thank you for your input !
P.S. I can get back to working on this set since my resistor that I needed came in today !
This is the replacement guide for transistors by GE parts. So, GE-3 is your power replacement for AR14 Just ...morzh — 04:57 PM
Philco 91 Restore Code ??
How do I know if AVC is OK? For the compensator cap I settled on 330pf. Its much closer now and close enough for me. I ...dconant — 04:46 PM
If the small signal ones, take any Ge transistor with unity gain good enough and Vce max 30 or so V. For the output....y...morzh — 03:43 PM
Yes, Michael. This winter I repaired this Westinghouse, RCA 121 and Zenit 5S29. All that remains is to veneer the Zenit ...RadioSvit — 03:28 PM
Thank you. I have one board completely de-populated. Just looking for the correct values. I'll let you know. Still h...R3Sons — 03:13 PM
Is this the one from the Fall Kutztown 2023?morzh — 02:59 PM
If it does not get narrower with strong signal and your AVC is OK, it could veru well be that the shadowgraph's magnet i...morzh — 02:58 PM
The width does not get narrower with generator. I think I will try some other cap values.dconant — 02:56 PM
410pF is a large capacitance to parallel to a compensator. As for the shadowmeter....yes, 3/8" is a bit wide, bu...morzh — 02:49 PM
My new nostalgic video... My weekly video on radio history Who is interested - come, watch, critically evaluate the qu...RadioSvit — 01:47 PM
There are currently 3022 online users. [Complete List]
» 1 Member(s) | 3021 Guest(s)
