i just got a Philco chairside
I have the radio all recapped and it sounds very good, no hum, and loud and clear.
 I am just waiting for some safety caps.  the cabinet won't get done until next spring.
 Dan in Calgary
   Living in Calgary Alberta
Hello Dan,
Way to go !!!
Hi Dan,
Looks good! You haven't told us what model chassis is in it...Canadian?
I don't think it is Canadian,and I am not sure how to find out .
       The model is 38-15. [121-124]
  I got the schematics from my Riders book.
              I just ordered a bunch of caps from Just radios ,and that was before I knew I needed safety caps.
 To make a special order would be too costly.
      I would gladly pay one of you guys to send me two .01 y caps in the mail. I have pay pal.
    Thanks
 Dan in Calgary
Dan,
Check your PM.
Thanks Ron;  All the guys on the forums are great and always willing to help out others.
 Thank you very much
 Dan in Calgary
