Philco 46-250-I
See also the cabinet thread.
After getting the chassis out, here's my first look at the state of the thing.
[Image: https://www.dropbox.com/s/6d70qjvng0fbbt....jpg?raw=1]
[Image: https://www.dropbox.com/s/alvmrioh7lt27w....jpg?raw=1]
The dial scale is held in place with 4 screws and two metal strips.  The glass itself rests on two strips of rubber which of course have deteriorated but should be easy to replace.
[Image: https://www.dropbox.com/s/w5wxnwiqqngqec....jpg?raw=1]
The original electrolytic firecracker style cap has been replaced with a Sprague and lots of extra wire!
[Image: https://www.dropbox.com/s/edg9gq3hybgli1....jpg?raw=1]
Here's an image (from an internet search) of an original.
[Image: https://www.dropbox.com/s/rtlbw8nac4vamp....jpg?raw=1]
Good news is the candohm style resistor R100 is good.  I will take off the tuning cap and give it a good wash since I doubt I could really get it clean while still in the radio.  One of the two dial strings is already off anyway.  The on-off switch was showing some resistance when it should have been closed so I took it off the set and gave it a little spray of cleaner.  That seemed to clear it up.  I used just a little of the DeoxIT Fader F5 since the regular DeoxIT can damage the volume pot section. More later...
Silly me, you are right! I read and wrote nF, but was thinking pF.jrblasde — 10:48 PM
0.01uF and 10nF are the same capacitances :lol: Its the rating. Yours are rated to 500V and the Y2 are up to 300V. Obvi...morzh — 10:41 PM
You’re right, yours are much smaller. I must admit that I ordered these without much regard to size. I ordered them back...jrblasde — 10:29 PM
What should I offer?
Thanks, that makes sense. I searched Hepplewhite on Google, and saw some fancy dining chairs.jrblasde — 10:23 PM
My memory had not failed me when I was writing about those inductances. I found them, both 5.6mH and 10mH, both small ax...morzh — 10:21 PM
Joseph, Yes you could do that too. But why did you choose to buy these conspicuously large capacitors? 10nF Y2 caps sho...morzh — 10:02 PM
Thomas Sheraton gave his name to the style. That is others in 19 century took his name and assigned it to the style. G...morzh — 09:59 PM
Excellent point! Thank you, sir.jrblasde — 09:58 PM
Hello Joseph, That looks great only thing I would make sure is that screw has good clean area where it contacts the gr...radiorich — 09:50 PM
Here we are. Boomer Sooner!  :lol: jrblasde — 09:40 PM
There are currently 3281 online users. [Complete List]
» 1 Member(s) | 3280 Guest(s)
