What Tube tester would be best to buy
Threads: 17
City: Hayden, ID
I’m looking for a tube tester that works, without spending an arm and a leg for it. Also what would be the best one to look for? Especially for older Philco radios.
Philco 41-295X 4 band radio.
I'm 67 years old, in north Idaho.
Threads: 112
City: Medford OR (OR what?)
Hickok 533. All of the good at a better price than a TV-7.
Threads: 13
City: Greenwood
State, Province, Country: Delaware
I use an I-177 made for the signal corps for WW2; found it locally and had it calibrated all for about 200. Works great!
Threads: 17
City: Hayden, ID
Ok I bought a Jackson 648s for $236. So far it is working great. Going through my Philco 41-295x I found 5 bad tubes, I have them on order, so hopefully it will work now.
(This post was last modified: 11-07-2019, 10:38 PM by nortonz.)
Threads: 15
City: Fort Worth
State, Province, Country: TX
Good choice! I like my 648S. There is a Jackson Model 648 tube tester manual that can be bought from https://vacuumtubesinc.com/index.php/boo...anual.html for $28.50. It's a bit pricy but useful.
Threads: 17
City: Hayden, ID
I found a free updated one on the web, plus a very complete tube substitution manual, it was also free. I can upload it to the Phorum is you need it.
Michael
Threads: 1
City: East Greenbush
State, Province, Country: New York
I need a tube tester so I can restore my radios. Should I be considering a utracer3 or something more traditional like a Hickok model?
Threads: 13
City: Greenwood
I had not heard of the uTracer; I have an old I-177 that I use for these old tubes...something like that will need to be calibrated, probably
Personally, I think the tube tester which offers the best bang for the buck is the Heathkit TT-1, with its optional TT-1-A adapter. It is a dynamic mutual conductance tester, and is sometimes overlooked by those who want the Hickok testers.
I picked mine up at an auction of an old radio-TV repair shop in western Kentucky back in the 1980s. In more recent years, I fully recapped it, found the calibration instructions online, and calibrated it.
I consider it to be the best two dollars I ever spent.
Threads: 1
Am I correct that the consensus is a conventional tube tester is preferred to a curve tracer?
Threads: 562
To repair radios you do not really need a curve tracer. If you are into stereo amps, that might be justified; else a mutual conductance tester is all you need. And some would argue that even that is too much.
Threads: 110
City: Omak
State, Province, Country: WA
Hello nortonz,
My self I use a Precision 920 and a B&K tube tester and some other handy test equpment to have is VTVM plus Signal tracer and Signal generator.
Threads: 30
If you're in Canada, a Stark 9-66 is one of the best testers built/sold here; Stark used Hickok patents.
Threads: 1
Thank you for the help. Now I know how to proceed.
Hello Tim,
Hello Tim,
Hi Dan,
Hello Tim,
bk1077bradiorich — 09:01 PM |
There are currently 7431 online users. [Complete List] » 2 Member(s) | 7429 Guest(s)
