What is this??? need an id....
can someone help id this?...........thnx
http://flint.craigslist.org/atq/2495624159.html
It isn't a Philco, so moved this topic to the appropriate section.
Sorry, I don't know what it is either...but I know what it isn't... Icon_wink
Erg, that emblem under the dial looks very familiar. I almost want to say it's an early Wards Airline radio set, but I'm not totally sure. It is a nice complete looking unit for the price though. The tag is intact on the back, but the picture is too small!
I'm just like Jayce, I've seen that emblem but I just seem to place it. I was thinking maybe a Knight but I too a quick look and didn't see it. Maybe a Lafayette? I don't know.
Sorry OM
Looks like an Amrad logo to me, and the radio looks very similar to the Symphony that was part of their Bel Canto series from ~1929 or 30. Amrad went belly-up in 1930 so this may be one of their last sets.
http://www.radioatticarchives.com/radio.htm?radio=8620
You nailed it, Eliot!
There are currently 8918 online users. [Complete List]
» 2 Member(s) | 8916 Guest(s)
