38-690 tube locations
Hi guys -
Looking for a source for tube locations on a 38-690, specifically the power chassis mounted at the bottom.  None of my paperwork or schematics show their location.
Thanks and Happy Thanksgiving!
Right here in the Philco Radio Library. Open Service Info and select 1937-38 Wiring Diagrams. Should have what you're looking for. Take care and BE HEALTHY! Gary
Thanks but unfortunately it does not.
Still searching.
Found this on the… Philcorepairbench.com  site.
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
Thank you!
There are currently 2263 online users. [Complete List]
» 1 Member(s) | 2262 Guest(s)
