philco 38-8 back wood or cardboard ??
I'm finishing a 38-8 and the back has 6 clips to hold on the back. does any one know what it looks like or where to get a replacement a photo of one would be great also oh and do you know if this radio had a built in antenna
thanks
john
No built-in antenna according to the schematic.
Hi
The back was not made of wood. It was a fiberboard type of material, rather lightweight.
thanks for reply
john
There are currently 10274 online users. [Complete List]
» 3 Member(s) | 10271 Guest(s)
