89PHILCO
Hello Bradley,
Very nice !
Need some help the schematic does show numbers of post  very good.
Do these numbers look good?
Cadmium cleaning.
Whats the safest way to clean it?
Current condition:
I've had good results using Simichrome buffing compound and soft cloth rags and cotton swabs. Wear disposable gloves and throw them and the rags out when done. It wont look brand-new, but very presentable. Take care and BE HEALTHY! Gary
There are currently 9521 online users. [Complete List]
» 1 Member(s) | 9520 Guest(s)
