retaining clip "what is it's correct name "
Hello Everyone,
one my friends  asked me if  know what this retain clip is what is it's  correct name for it,
It is either a
- Split rivet, or
- Push pin.
Hello morzh ,
Thanks !
P.S.
I found a post on ARF they call them They are called Trimounts, Part No. 7375-F
Eico 232 VTVM Schematic
