Philco model 96
has anyone measured the inductance of the model H speaker field coil? would like to replace the speaker assembly with a newer one but want to use a replacement inductor.
https://www.philcoradio.com/phorum/showt...?tid=16852
Similar discussion.
I'd say 20H or about would be good.
There are currently 8425 online users. [Complete List]
» 2 Member(s) | 8423 Guest(s)
